RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
And if so how well does it work? I need brakes and I cannot lock them up 93-97 Toyota Land Cruiser Hydro-Boost Conversion
The first question to ask is will it work with the factory ABS?
Now the second question why do you need this![]()
and sounds like your new, I dont have cracked OM anything on truck. not even rubber inside door jambs.
Shoulda called him "sport" just for the icing on the cake.just a little east coast sarcasm, take it easy
Touche'. It seems that I may have cut off part of my ear.Excellent work sailor
It would require tyng into the pressure side of the power steering. That means removing your gearbox and having it ported (and changing out to 105 shaft while there.
I can’t tell you if it will work well on our trucks but probably every diesel truck out there uses hydroboost.
I did hydro-boosted brakes on my Ramcharger a while back. I think I got my stuff from the same company you posted up. They worked magnificently! Thanks for posting this, I will be watching to see how it goes for you. There is a reason someone designed a hydro-boost set up for the 80 what with the mix bag of positive to no change results after abs delete.
, and Toyota is pretty good, buy new lines and flush/bleed the system, I can easily put them on my cruiser, because I have a Cummins, and I am happy with my stock setup
I will make a decision on this issue after I delete my abs and install an adjustable proportioning valve.But the Dodge brakes are known to suck, and Toyota is pretty good, buy new lines and flush/bleed the system, I can easily put them on my cruiser, because I have a Cummins, and I am happy with my stock setup
