Harmonic Balancer Nut
I know on the 1FZFE it's 410nm - or simply bloody damn tight.
My totuque wrench only went up to 200 odd NM so I ended up welding a 30mm socket to the end of a 5ft long piece of RHS and hung off it. I don't like it's chances of coming undone. I also put a small smear of blue silastic on the under side face the large washer that is part of the nut.
Have seen this asked so I thought it was worth posting.
Torque wrench
Torque wrench rental
400lb torque wrench
Autozone will rent a 3/4” 400ftlb wrench and it’s friggin huge.
I’m trying to get this thing back together before snow flies tomorrow. I was wondering if anyone had the torque specs for camshaft nut that holds the harmonic balancer in place on a 3FE. Thanks.
I think you mean 'crankshaft bolt'. Its tight....real tight. A bit over 300 ft. lbs. on my '97, possibly different for your.
