I've got it all figured out now. Stock brake line is 4.75mm OD. The fittings are M10x1.0. Flare ISO Bubble. Torque is 11 ft/lbs. The plan is a complete removal of the ABS and LSPV. I'll replace the LSPV with an engine bay mounted Tilton proportioning valve. The ABS MC will be re-used. I'll start my own thread with pics when it begins. Right now I'm just getting all the parts together.
The Tilton manual proportioning valve will be mounted underneath the MC where the three way fitting once was. The ABS MC has only two outlets, on more forward on top, and on more to the rear on the side. The rear outlet will connect to the new Tilton valve and then to the line running to the rear. The front has two lines and they will be connected to the more forward outlet using a new three way fitting. In the rear, two lines come into the LSPV, with only one coming out in the stock configuration. I'm only using one of the stock lines to the back, and a new tube joiner will connect the single lines. This keeps cutting, flaring and bending to a minimum.
I'm also installing speed bleeders and longer brake lines cause I'm going to 12" travel Doetsch prerunner 8000 shocks soon. I'm really excited about documenting this because no one who has done this has really documented the bypass/removal of the ABS and the LSPV. And I will also be fabricating spring retainers to keep my wee springs from coming unseated.
This has been a fun thread of talking to myself, but I learned alot from the research. Of course no one even threw I guy a bone on this site
