H55F + Split Case Length
San Diego, CA
Looking into a 5spd swap and want to compare my current setup with the dimensions of a H55f / Split Case. Does anyone know:
H55f Case Length?
H55F + Split case overall length?
I went through the FAQ and quite a few build threads, but haven't seen these dimensions shared.
Thanks,
Covered in the 60 series section ad nauseam
There was a late H42 and transfer for free in the classified section. That has the dummy spacer on the back of the transmission. The length with the transfer case is the same as the H55F. If the member still has he might be able to measure it for you. my 40 series H55F and transfer is 150 miles away otherwise I would measure it for you.
H41/H42 Short ~11"
H42 Long/H55F ~14.25"
Split TC to rear face of rear output flange ~10"
Combo's:
H41/H42S w/SC ~ 21"
H42L/H55F w/SC ~ 24.25"
Those are rough tape measure eyeball numbers from a few setups I have here at home but should get you close enough for planning. I've got better measuring means at the shop I
If you need super accurate.
