For Sale H55f (NY)
Status
Not open for further replies.
Metro NY
SOLD
This is a non-US 5 speed STOCK TOYOTA transmission that fits in Toyota Land Cruisers. These were supplied stock in other parts of the world while Toyota USA gave us 4 speeds instead - this is the tranny all FJ60s should have in my opinion. The 1st gear is lower than on the 4 speed giving you better control under tough conditions and the 5th gear overdrive lowers highway RPMs saving engine wear and GA$.
It can be fit into any early Land Cruiser including the FJ40, FJ45, FJ55 and FJ60. it is a direct bolt in for FJ60s after 7/1985 (that have the extension housing on the 4 speed). Modifications vary for install on other models - often only drive shaft modifications need to be made. I was running this in my FJ60 and I have installed another in an FJ40.
This tranny is used and in great condition. it has had Amsoil synthetic gear oil in it since I bought it used in about 2005. I have only put about 35k miles on it since then. No noises, no problems. Comes with the shifter and oiler cup (needed to add to your transfer case to properly oil the 5th gear - this is a stock Toyota part, not a modification)
Pictures available upon request... come by and pick it up! Located on Long Island, NY Price is $1000 picked up. If I need to take it to a trucking company for them to palletize and ship (all costs will be paid by you, COD) I'll need another $50 for the trouble.
Mark
I haven't searched yet, but how involved would it be to hook this up to a 350?
Send a pm if you don't want to clutter your FS thread.
Same as a 4 speed... adapter bell housing or Atlas
Off to do some searching to see if this will work. I don't think my OM617 Turbo will have the power to push it in 5th gear anyway with 3.73 and 33" tires. Hmmm off to do some homework on this.
Also I am unable to find any build threads with an H55 in a later model FJ40 with the tank under the body? Will the transfercase move back into the tank? Again going in an FJ43 so things may be different but should be the same up to that point.
I bought it used in 2005... Put 35k on it since. From Aus. As far as I know. Gas truck. No noise or problems...
Lots of talk... no takers yet.
Trans
Smokin deal !!! I have this trans in an FJ55 and an FJ60 best upgrade you can make, both convcersions easy, the 60 (5/85 Prod Date) was a swap in with no mods! The FJ55 was easy - You will probably want a late FJ60 transfer case. Will move the GS back about 4 inches. But now I can cruise at 70 MPH at under 3000 RPM.
These are hard to find - and having done business with Woytovich in the past - he's a stand up guy.
Any idea what shipping would be to a business address in Tulsa? 741112
If it is reasonable - I am very interested.
Local deal pending but shipping to Tulsa would probably be $150 or so.
Status
