- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Allow me to summarize:
H41 or H42 are the two ratio packages for the H4* cruiser tranny. H42 have numerically lower gearsets optimized for easy street driving. H41 has numerically higher gearset that yields a "lower" first gear. Better for off-road use but has bigger RPM drop between shifts on the street.
On the front end, some H4* trannies have the long, fine spline input gear for use behind B series diesel. Other H4* trannies have the short coarse spline input for use behind F series gas and H series diesel.
On the top, some H4* trannies have the forward shift tower for use in *J4* and FJ5*.
Other H4* trannies have the rear shift tower for use in *J6* and *J7* chassis.
On the bottom, 1980-earlier H4* have no provision for a tranny crossmember mount. 1981-newer *H4* have the boltholes for a tranny mount.
On the rear, some H41 trannies have 10 spline output for use in 1973-earlier trucks. these are very rare anymore.
Most '74-'80 H4* trannies have 16 spline output for use w/ common 4-speed T-case.
'81-newer H4* trannies have 19 spline output for use w/ split T-case.
'85-newer H42 trannies have extended 19 spline output to make them same length as H55 which became world standard in 1985, replacing H41.
So the answer to "Can I swap my H42 for an H41?" is yes, as long as you get the right one. Over the years, there are 2 different inputs, 2 different shifters, 3 different outputs and 2 different cases.
