H41 Availability
Poser said:
The advantage to staying with the 4speed from the 74-55 would be:
No drive shaft modifications, as the split case set ups are longer, and would require you to shorten the rear shaft and lengthen the front.
This is incorrect. The 74-80 4-speed& t-case is architecturally identical to 81-84 4spd& split t-case. transmission is the same length, t-case is the same length, d-shaft flanges are the same.
The four speed cases are the same length, however the split transfer case is longer than the earlier one-piece case designs.
Again, the t-cases are the same. It's the fifth gear housing on the later 4-speeds and H55's that makes the additional length.
HTH
You would be able to retain your parking brake set up without having to spend another 500.00us plus on a conversion kit to make the parking brake attach and function on the rear of the split case, as vehicles equipped with a split case in North America do not have a parking brake on the transfer case, but rather on the rear axle.
Did not think of this one...
What about adapting toyota mini truck rear axle backing plates to put the parking brake at the rear axle like the later cruisers? :confused:
Or...
If the units are this similar, how hard is it to mount the parking brake to the drive line without lots of $$$$.
On another note,
Are the FJ60's geared 3:73 and my 71 is geared 4:1?. Is the gearing the same in the 74 4 speed as in the FJ60 4 speed?
Thanks for all the help
Chuck
Thanks for the clarification Jim...I forgot that they did not change lenght until later in the run...
:beer:
The shafts in the cases are not the same, nor are the rear housings that allow for the backing plate for the parking brake assembly to attach to the case.
Top gear in all tranny's is 1:1...so if you are looking for an overdrive...it is not there.
Good luck!
-Steve
Thanks Steve.
Have you heard of anyone adapting rear mini truck brakes including e-brake to a cruiser.
Chuck
Chuck-
I am not aware of a set up like that, and if having the parking brake on the rear axle was a focus of mine, I would go with a disc brake conversion, and make them work. I built a new rear axle for my Red truck, and the disc brake parking brake works.
I guess if you wanted to, you could do what Brian did in his Trails article about building a centered rear axle with mini truck parts and a Land Cruiser center section, only leave your center where it is, and weld the mini outers onto the housing....but you would then be into custom axle sahfts, which would cost more than going with the parking brake conversion on the split case...all depends on how much work you really want to do I guess....
Good luck!
-Steve
fj40Matt said:
So if the split case is that similar is there any problem with not using the rear crossmember when swapping the newer components (excluding the longer H41/H42/H55) into an older Cruiser?
No problem. It's a bolt-in, except for the lack of a parking brake drum.
Now I'm confused. Why adapt minitruck backing plates and little drums, when you could just use 81-newer LandCruiser backing plates and large drums? They have different bolt pattern, but nothing a drill press can't deal with.
On another note,
79-87 USA Cruisers have 3.70 R&P gears. Just about every other Cruiser in the USA had 4.11 R&P.
The H42 4sp. tranny used in USA cruisers '73-87 has the same ratios, all years/models.
:cheers:
Thanks Jim
I will now start looking for 81 newer backing plates etc. The gearing question was just to set my mind straight.
Dont worry, i confuse myself all the time.
Chuck
I've got 60 series axles I'm going to put under my troopie. I'll likely be getting rid of the split case e-brake that I've got at that time and use the 60 series axle e-brake. Not sure what your timeline is and if you want a split case e-brake. Just throwing it out there.
HTH
the cases are the same on the later 60's (from the US) as on the earlier cases. however they use a removable spacer between the tranny and the Tcase to makeup the addition length of the 5speed found in 60's elsewhere in the world, on the later ones. that is how the 5spd is a drop-in-swap on later 60's.
