H152 swap, 1hdt Won’t start afterwards
Washington, USA
Tried everything and can’t figure this out! I just did a h152 swap from a a442f on a 92 Land Cruiser with a 1hd-t. Once everything was in, I tried starting the truck and nothing happens. Power to car is good, then I turn the key and everything turns off and gives a very slight single click. I connected everything underneath and did the reverse lights with a harness. The reverse lights work fine and I connected the two wires for the neutral safety switch to each other. I verified my batteries have good voltage and checked to make sure the starter is connected properly. Anyone have any idea??? TIA
You have to press your foot on the brake to start an auto as far as I remember (I try to avoid...), what have you done to remove/override that system?
Bad ground, loose terminals, missed connection.
Good luck.
Conversely get under the unit and tap solenoid starter wire with a jumper to Positive starter feed wire from battery.
If she turns over then work both ways.
