Clear rubber/plastic hose (somebody here will recall the size, I think 5/8) and a funnel. Drop it down under the hood by the exhaust on the passenger side. You need like 8’ of hose. When you put the AT205 in, chase it with an ounce or two of transmission fluid so you get it all in. Before you pull the hose out, go up under the truck and make sure none of the low points in the hose are holding fluid. Chase it into the trans. I use a bolt and a hose clamp to keep from making a mess pulling the hose back out of the engine bay.
