^ currently debating between regearing to 4.56 along with the ARBs and onboard air or Harrop e-lockers.
I already had an ARB twin for airing tires, but still went with Harrops. They instantly engage/disengage with no noise. Your climate is likely as humid as mine, and running lockers off the ARB would end up putting quite a bit of water into the air lines and the lockers themselves (which may then freeze when snow wheeling). Water sometimes drips out of the air chuck when I'm inflating tires, and my shop compressor gets a ton of water in the tank.^ currently debating between regearing to 4.56 along with the ARBs and onboard air or Harrop e-lockers.
What turned me was a YouTube channel I used to watch (FabRats - before I quit watching YouTube due to it being a time sinkConventional wisdom is that the ARB air lockers are more robust than the e-lockers, but also more problematic to operate.
And I would agree. I have had ARB air locker on previous rigs. They worked more often than not, but keeping the air system working properly was a challenge at times. And a couple of times I had to pull diff third members to replace seals in the lockers, which was a lot of work especially for the front diffs. The e-locker in my GX has been trouble free, and I would go with it again if given the choice.
My new arb brushless is mint. But even the connectors they use broke. I dont think i will buy another ARB product for a long time.What turned me was a YouTube channel I used to watch (FabRats - before I quit watching YouTube due to it being a time sink). He had an ARB Air Locker in a 14 bolt where the air line and seals kept getting nicked. I think he pulled it out 2-3 times to repair before finally switching to a Harrop.
I would say that it's still possible to damage the external wiring on a Harrop, however I carry spare wire, strippers/crimpers, and connectors in the tool kit in my rig, and so it would not be hard to perform a trail repair on ripped/torn wiring.
My Harrop got tested good this winter - this was after about 1/3 mile of 3,000+ rpm wheel spin getting up a steep hill in nearly a foot of snow, with the rear locked the whole time (I tried F and R locked, but the rig almost slid sideways off the hill). Although it's possible something may have broke if I had suddenly caught traction, but if it had, the 3rd member is still under warranty. I'll be testing it more in the rocks on a trip to CO later this summer, and will eat crow if I do break something.
How much does that raised boss interfere with the wheel? If it's close, perhaps you can have a machine shop put them on a lathe and turn them down a wee bit. But other than that, yeah, you may have to machine that boss off with a mill.Has anyone run into issues when running a factory GX550 wheel on a 460? Just had a 3 inch Ironman lift installed today. Running 550 Overtrail wheels with a 285/75/18 Toyo RT Pro. Using the 1.25 spidertrax hub centric spacer as well. Spacer bolts up but the ring of the spacer is bigger than the bore on the factory wheel. I thought hub centric was the way to go, but I’m guessing I’m wrong. Do I have the bore on the wheel milled to fit? Do I have the lip on the adapter milled off? Do I use a “non” hub centric adapter? The lip in question is circled.
You need a 106.1mm to 95.1mm center bore converter. Spacers are fine to run as long as you maintain them - which means taking off the wheel to check the torque of the spacer when you do maintenance AND the torque of the wheel. The newer 6x139.7 Toyotas also have a larger stud, M14 vs M12. So make sure you account for that.Has anyone run into issues when running a factory GX550 wheel on a 460? Just had a 3 inch Ironman lift installed today. Running 550 Overtrail wheels with a 285/75/18 Toyo RT Pro. Using the 1.25 spidertrax hub centric spacer as well. Spacer bolts up but the ring of the spacer is bigger than the bore on the factory wheel. I thought hub centric was the way to go, but I’m guessing I’m wrong. Do I have the bore on the wheel milled to fit? Do I have the lip on the adapter milled off? Do I use a “non” hub centric adapter? The lip in question is circled.
wheeladaptersusa.com
I went with black line very pleased. And the black line logo emblem for the rear. Somewhere on here I have the part numbers for the black line. Id do it again depends on your vehicle color of courseSpeaking of which anyone know the part numbers for either 460 Blackline tail lights or 460 sport (all red) taillights?
You mean this?saw a 2000s Toyota Truck break the LBJ in the middle of an intersection yesterday. I've seen the pictures of 3rd gen 4runners break the LBJ and makes it seem like they have extreme camber and it looked exactly like that. the guy was able to drive and pull off the main traffic. I was secretly hoping I could use my winch though.
check or replace your lbj if you have this generation of vehicle.
My last tacoma did this pulling into the dealer to buy a replacement.You mean this?
The GXs and LCs don't suffer from this problem as they have a different design. But the 1st generation Sequoia, Tundra, 2nd gen Tacoma and 3rd Gen 4Runners have this lower ball joint, so it's a maintenance item around 100k.
almost exactly like that. yep, im familiar with the issue as I read about it a lot online and glad they changed the design. we also have a 4th gen 4runner and dont have to worry about that.You mean this?
