Gun rack options
Amistad Lake/Port Mansfield, Texas
Hey guys, im looking to mount an overhead gun rack in my 80 amd was wondering if anyone knows whats under the headliner. What im thinking is mounting the rack shown int the photo on the cross member behind the dome light with some larger selftaping screws. Does anyone have a pic of this area with the headliner removed? I guess my second option would be to buy one of the adjustable racks like I mounted in my 73 and fab some brackets to fit the grab handle holes but would rather save the funds for beer, ammo etc...
H
Thanks, I'll have to look closely at this. Do you have any idea on a single rifle rack that is forward, by the visors? Or is
that a non-starter? BTW sound suppressor or just padding?
What about hanging them further behind the second rowin the cargo area? I have been thinking about lately as well. Further back does make it more difficult to reach quickly. :meh:
Minus the ability to get to quickly this is my plan, well at least integrating into my attic rack.
^ This is what I've been leaning towards. Now if I can make a rack that can double as a cargo barrier and then flip up to the attic rack position...
I've already got a 2'×4' rack mounted between 3rd row seat grab handles so that space is out.
I wonder if anyone has ever used a vertical style rack mounted behind the center console? I have one I took out of my kawasaki mule after it sold, will dig it out tomorrow an audition it.
If you mounted behind the cup holders you could probably fit a single mount. Or if you didn't care about folding the seats forward a floor mount would work depending on barrel length.
I would like to put my 2 cents in,
I have been trying to figure this out for a while now. The problem I have found with most gun racks in the cruiser is that its difficult to stop the car, open the door, pull your rifle out of wherever it is being secured, not hit anything with it on the way out the door and most importantly not point it at the person sitting in the passenger seat.
I had some success laying the rifle across the dash board however I am right handed and drive an RHD cruiser so it's a natural move to open the door and then grab the rifle with my right hand and slide off the seat and out the door making sure to point the business end at the windscreen as I go out the door. probably not so easy for guys with a LHD cruiser. The problems with that is the bolt handle rests against the glass and if you drive up any sort of steep grade then the rifle comes sliding off the dash. Also this really only lets me use one rifle at a time and I often find I need quick access to more than one caliber.
Something that lets me grab 1 of 3 different rifles as I get out the door without doing any of those things I mentioned above would be great.
I suppose this thread is more about securing your rifles while you drive to your spot and not actually shooting from the cruiser.
I dont know about others but I shoot from the cruiser quite often, I call my side mirror a (texas gun rest). When im actually hunting something irest the rifle horizontally between the driver seat and console rested on the useless cup holder thing but it makes it a pain to use the seat belt when on the highway. I'll play with the vertical rack tomorrow and report back.
Junior80, have you ever tried a rifle rack above the visors like was mentioned earlier? Ive seen overhead consoles on some of AU cruiser that dont have factory moon roofs.
I haven't. I guess I couldn't find anything that I liked the look of, for a long while I didn't have an 80 series and I was shooting out of my old man's 76 series cruiser which has a place to mount rifles on a home made plywood box that carries a fridge and battery and all your gear so you reach into the back window and pull them out. My 80 doesn't have that. rifles mounted on the headliner would be just that little bit to high to reach comfortably.
I never put a rifle in the car with a round in the chamber but I still want to avoid the muzzle pointing at the passenger.
I wonder if there would be a way to mount it on the inside of the door? would probably mean removing the armrest tho.
I used a vertical rifle rack in my M-37 (Dodge Power Wagon) very successfully for years. Haven't tried one in the 80. The butt pocket bolts to the floor, and the upper piece would bolt/epoxy to the dash. It was easy in the all metal Power Wagon - might be a little trickier with a plastic dash but still doable. It kept the rifle out of the passenger's way and in the safest possible position in case it went boom, for some reason.
I'd do this before I started messing with the overhead.
Use a monkey fist so you get something like this.
Ok, I dug out the vertical floor mounted rack and it looks like its gonna work. I made an adapter plate and am playing with the location and trying to decide if I want it angled forward for longer barrel lengths (22"+) or vertical for those shorter. Currently im leaning twords vertical as most of my rifles are 22in or shorter in bbl length. Will get some pics up tomorrow once I get closer.
Here's some trial run pics of the rack in its vertical position. I designed the adapter plate to be semi modular, it can be rotated 180 deg to position the rack closer to the console or seperate brackets can be made to locate it further rearward for forward angle mounting which allows longer bbl length.
