Gulf States fender flares - availability?
Land Cruising
Just bought a 2007 LC and someone hit the side of it but didn't leave a note. People are great.
My LC is from Texas and the flares were installed at the port by Gulf States Toyota.
It doesn't look like there is any body damage, but one of the rear flares is cracked and broken. Both parts. Are these flares still available? Does anyone know what supplier made them? I
Post a pic of the side that's in tact - they came in a couple colors. I'll take a look... I can't remember if I threw mine in the trash or tucked them away somewhere...
Thanks all. I'm not all that into the way they look, but my truck is white/tan two-tone and I think they help with the lower portion. Didn't know Bushwacker made them.
Yes, Bushwacker makes them. Check out my follow-up post about what I found when I took them off. In the what have you done thread, complete with pictures. Spoiler alert .. about a pound of dirt behind the front flairs. Lucky my fenders hadn't rusted out. Mine are in the trashcan. Wouldn't advise installing them.
Mine is the white/tan two-tone also. IMO it looked way better after removing the flares. They're easy to remove. Requires a little elbow grease to get rid of the adhesive under them. May need some touch-up paint too. Well worth the effort.
That being said, which one do you need? I still have mine taking up space. I'll send you one of them if you want it. Mine is an 05. I'm assuming they are the same color.
I have a set I'm going to take off in MS
Here is what I found waiting behind mine my front flairs. :bang:
Luckily, no rust!
I took mine off. I did put them up for sale but no bite. They serve no purpose other than to damage the clear coat. When I took them off the clear coat had been cracking from the rubbing. Also there is a one inch rust spot on my rear panel. Useless.
I have a 2000 LC with cracked molding flares on left passenger door and rear wheel side panel. I am looking to buy replacements. Any suggestions appreciated.
