- Thread starter
- #41
Here is a version that cappy suggested.
that I can't leave my phone charging in the car or that my streamlight will not charge while the key is not on.
The fuse mounts here on the tray:
Let me know if you have any more questions. Hope this helps.
Got a wiring for the 12 circuit block? I have only seen the 12 circuit with 6 constant hot and 6 with ignition on
I have the same 12 circuit block from Blue Sea. There is only one 12v input to the block, so you either wire it constant or switched, not both.
I misread the article that I saved
This guy wired a single 12 circuit fuse block so two separate 6 circuit systems are triggered by two separate relays
12-Circuit Switched Fuse Box - Toyota FJ Cruiser Forum
is there a benefit to having two relays?
