I recently purchased a Die Hard Platinum group 31M AGM battery (Sears: Online department store featuring appliances, tools, fitness equipment and more) to replace my stock battery. When I want to install the battery I found that I would have to modify the existing clamp or make a new one. So long story short, I opted to make a new one. Due to the popularity of my solution, I was prompted to make some more brackets so that others may benefit as well (https://forum.ih8mud.com/100-series-cruisers/218815-another-can-i-fit-battery-my-100-thread-2.html).
So, for those of you with kluged battery clamps and trays or those of you on the fence about getting a new battery, I have a solution!
Each retrofit kit includes a battery clamp with either a Sombrero or an LX logo, a battery tray that BOLTS to the body using existing holes with a mounting position for a small fuse block (sized for a blue sea maxi fuse block but you can put anything you want to there), a buss bar to extend your battery terminals, all necessary hardware to make the connections, and 1/4" neoprene tape to prevent chafing on the tray and clamp. Everything is made of 1/8" cold rolled 1020 steel and is sandblasted so that you can finish it however you want.
Each kit is $70 shipped. Let me know if you have any questions or comments.
-Ryan
-Ryan
