- Thread starter
- #21
As OP, nothing to update on my end. It happened again this winter but mostly when it's cold and humid (like 40 deg F and humid/rainy). I sprayed with silicone again and it went away, possibly until next winter.
forum.ih8mud.com
forum.ih8mud.com
I wouldn’t call my noise a feature. It’s an annoying squeak/groan. Spraying some silicone spray under the boot where the steering shaft goes through the firewall seems to help for a month or so but it eventually comes back.Apparently, this noise, or at least steering column noises, are a "feature" of many generations of LCs.
This thread had some traction on a DIY fix.
2009 LC- Steering Wheel Whine?
forum.ih8mud.com
The above thread sort of moved to the following thread starting at the post linked:
@linuxgod might be able to expound on whether he performed this maintenance and if it worked for him. I have a similar noise so am also interested in a fix.
This thread is from 100 series and the final post is about lubing underneath the same boot the above post is talking about lubing under.
steering noise when cold
forum.ih8mud.com
Mine is definitely where the steering shaft goes through the firewall. Previously I tried to lift up the boot (which is tough) and spray some silicone spray into it. That did remediate the noise for a month or so, but eventually it comes back.Nah, yet again, posted too soon. Heard the creak again today.
I haven’t checked it out yet. Is there anyway to get some grease in there for a longer lasting fix?Came back again a few weeks ago as weather got colder and wetter. Sprayed again down into the rubber boot with silicone WD-40 and noise went away. See you in 6 months lol
Probably but I suspect it would involve a lot of dismantling. It’s pretty hard IMO to get the boot up enough just to spray some silicone lube in there. And for me it only seems to last a month or two.I haven’t checked it out yet. Is there anyway to get some grease in there for a longer lasting fix?
Would it make a difference if applying the grease with a syringe/needle type applicator?Probably but I suspect it would involve a lot of dismantling. It’s pretty hard IMO to get the boot up enough just to spray some silicone lube in there. And for me it only seems to last a month or two.
When I spray with the silicon wd40, I use the long tube attachment. I'd imagine you could do the same with a thicker lubricant.Would it make a difference if applying the grease with a syringe/needle type applicator?
I dunno. I can’t tell exactly where the noise comes from, except inside the boot.Would it make a difference if applying the grease with a syringe/needle type applicator?
Right, and as a reminder nobody knows what exactly we're lubing in there, why it's working, or what the result would be with anything other than a spray lubricant.I dunno. I can’t tell exactly where the noise comes from, except inside the boot.
When I spray the can has one of those thin red straws. But it’s kind of a “wedge up the boot and spray liberally as best I can and hope it worked” effort
