Grease all over inside wheels - Need Help
Lake Worth, Fla
Well everything has been going well with my '94 locked TLC for a year now. It's got 71,000 ,miles on it and today I check the tire pressure to find grease all over on the inside of the wheels. Can someone tell me what the issue is? How long can it be driven like this? I'm in South florida. Are there any shops anybody is willing to recommend. Here are some pics.
your inner oil seal is shot. Gear oil from your diff is traveling down the axle tube and getting into the knuckle cavity, causing this soup. Which then leaks out of the knuckle. Time for a knuckle rebuild.
I would also check the tightness of the four bolts holding the steering arms on the knuckle. They have been known to work loose, and this would also help aid the leak.
X a big 2. Wow - that's a mess. Don't know that I'd drive very much before getting that taken care of.
Okay, so a knuckle job is order? Can just any shop do it? How much should I expect to pay? Any do's and don'ts to be aware of? Any other work to do while in there?
Thanks in advance!
A lot of good threads on here about this. Search birf rebuild, axle seal, look in the FAQ sticky. There is a full write up. I had mine done at a shop for around $600 and felt like I got a good deal. Parts were from CDan. His info is in FAQ or the vendor Marketplace as well. Good luck!
From what I have read: your birfields will start clicking and you'll start wearing the bearings down inside if you don't do something about this. A repack/rebuild before this happens is less expensive from a parts perspective but I understand the labor isn't much different. I'm sure I'll be corrected if I'm wrong.
That $600 figure and the reference to CDan makes me think MDarius bought the bearings/seals/wipers/etc. from CDan and brought them to the mechanic. This is a good idea if you are not having a Toy specific shop or dealership do the labor. You really want to go OEM with the parts. X2 on not just any mechanic/shop...the rebuild is not difficult, but time consuming. I just did mine a month ago...$500 for everything, including wheel and trunion bearings (not aware of these being serviced by PO and 180K on the ticker). With 71K you may want to buy the wheel bearings and have the mechanic check yours and replace if necessary, return if not. Expect to pay $1200-1500 for parts/labor at dealership.
Good luck! A 94 locked with low-low miles...sweet!:)
Looks like a knuckle job is well over due! We stock these kits too. (special deals for ih8mud members)
did mine about a month ago with a tool kit from home depot and the FAQ on the laptop. Took me 16 hours (all weekend) but was worth it, since the parts were only $150 with shipping (JT Outfitters). Good luck! BTW, my axle soup was all over the driveway, worse than yours. Critical....
Cheers!
Yup! Sorry I left that part out. I have a mechanic I trust. They underbid the job and honored the bid. I offered to pay half the difference and they wouldn't take it. It should have been bid closer to $900 for their rates. They used the OEM parts from CDan without a problem. I printed the FAQ and the relevant section from the service manual...just in case they were using a Haynes manual or something. I specified the replacement fluids up front to ensure I didn't get any junk. I had them replace both brake calipers, the rotors, and pads as well. (stuck brake caliper needed to be replaced.) I think they did a pretty good job and considering my tendency to break things when I touch them, I'm happy I paid for the service.
FWIW it also looks like you have a goodly amount of water mixed in there....been swamping and not swapping gear oil have we? :)
Looks to me like you may have had water contamination that may have caused your inner seals to blow. I've seen leaking birfs before, but not this bad.
How long did you own it before it started leaking? Is this something that happened over a long period of time? Or is this something that you didn't notice until new wheels and tires?
Clean rig though.
Front axle rebuilds are not too difficult. Just take a a considerable amount of time to do it right. Most shops dont see LC's very often, much less axle rebuilds on them. Shop rates on cruisers tend to be high when the mechanics start to walk into unknown territory.
Good Luck!
Thanks to everyone who has chimed in so far. Here are more details. Keep the info coming. I'm a little confused by some comments like water in the diff's and long overdue for a knuckle job. I know this just started yesterday because it was washed last Saturday and it was perfectly clean. Now a big mess.:doh:
KTM - I bought the stock truck 1 year ago w/ 62,000 on it. All was perfect. I modified it. I know it just started leaking yesterday on a long trip.
Lowtideride - Thanks for the offer but I'm going to have a shop do it:cheers:
Dan - Yes I admit it's been mudding. That's all we have here other than sand (and anybody can go through sand). I have the diff fluids checked at every oil change because the truck is in the water so much (last check was only 3 weeks ago). Also, my breathers are routed to the gas cap and fire wall so I'm not sure how water would have gotten in there. Ideas?
Tenn - The soup doesn't drip on the driveway yet. :)
that's not bad axle seals, that's your cruiser rejecting
those god awful aftermarket mall-crawler wheels......
.....i'm jokin', i'm jokin'. :grinpimp:
QUOTE]
The job is doable even if you're a :banana: mechanic like me. Find someone who's done it, a few of the right tools and LOTS of time. Worth doing at least once. I guess I can say that now. Took me 16 hours for both sides, anally cleaning everything, swaping sides, replacing rotors and upgrading to 100 series pads. Would I do it again w/o a lift- HELL NO. Am I glad I did it - HELL YES! I know now in an emergency that I can get it done.
Jo - I know. I know. Remember tho - Your rig doesn't have to look like **** to wheel well. Image is important too. Of course I still haven't gotten rid of the stock steelies cause I can't bring myself to do it.
Brent - I've got access to everything I need but time. 16 hours sounds like a shot weekend if all goes well. A little trouble and then it's 2 weekends.:cheers:
BTW - Could this be the water problem?
long submersions will allow water to soak in...also if you stop for a long period of time or spend a lot of time in the soup....seals are meant to keep oil in, not water out.
I thought seals liked water cause the fish are there?:doh: What's the definition of long submersion? I don't usually stop in the water or mud unless I get stuck. I need to pull the diff check plug to see how it looks. I haven't yet.
