Dealer will want to charge around $1300 or so for parts & labor.
If you have a weekend and like to wrench even a little then buy the parts for CDan and give it go.
Its not that hard just messy and time consuming.
I did mine for $150 in parts and about 8 hours of work.
I think everyone should have to do this to drive and 80![]()
If the axle vents don't work properly (kinked, clogged, etc) they will not allow the pressures that build up in the axle to vent out and the seals can "pop" and cause a mess....rapid loss of goo.
This makes sense but what causes the pressure in the diff? Is it the speed of the axles spinning? Also, why all of a sudden after 100's of miles does the seal pop now and not right after the work was done.
So you are saying this happened quickly? Sounds like that the pressure problem may be an issue when you mention the breather extensions...check those before you redo the seals or you will see this again.
MDarius - Yeah! I think they attached a new length of hose to the fitting at the differential and re-installed the valve at the end of the hose. I'll have to double check this.
