- Thread starter
- #41
It’s pretty crazy at night down there
I see back door is getting dug out, not as bad as I have seen in the past, weather all plays a part in that. going down that during the race was fun!Went down to Johnson Valley for Thanksgiving. The truck worked really well . Except for my steering but I knew that was going to be an issue since I had not had time to install the hydro assist .
I have 609 axle front and rear . and 14 inch Coilovers front and rearAxle ? Which CO's ?
I miss that place. One day we will get back………Yes we ran Backdoor and Blueberry then Jackhammer At night its fun to go watch Chocolate Thunder . I wanted to run it during the day but never got the chance
This was a kit from Solid . But I have Willwoods on it now that I will most likely useWhich rotors are you using ?
My willwood rotors are a little thinner. I will measure when I get home . I like the willwoods because I can swap rotors the hat unbolts . My willwood brakes are very nice it stops the 40s very well. My guess is the solids will do the sameAre the wildwood & GM disc same thickness and hat depth ? My 6 lug rotors are for a 85 K5 blazer and they are thinner than those which requires the piston to stick out a bit, the edge gets rusty and they lock up, I learned and keep them coated which has worked but a thicker rotor would be right, i'll see what application Solid specs in the kit.
