I am not sure if the gauge is correct. While coasting down hill I am pretty sure the air flowing thru the engine bay will cool it off easily since it is idling only also the water in the rad will be cooled.cpg, I wonder if there is something off with your gauge or sensor or thermostat?
if the thermostat starts to open around 180-185, it is highly unlikely you would get any lower than that coasting down at high temperatures outside since the fan / rad are no longer in the picture when the thermostat is closed.
cake ?). I mounted it to the left side of the steering column near the air vent so I could still see the idiot lights (pics to come of some idiots). I routed the cable through the small gap around the steering column and tucked the cable out of sight inside the fuse panel. The fuse panel door closes because I unscrewed the OBDII connector and spun it 180° and mounted it pointing downwards instead of outwards.
