Good buy?
Box Elder County, UT
I've got a line on a 60 but I want a gut check/reality check from the forum since I've been out of touch with 60s for about 7 years.
84 with 275k miles
The good:
- <2k miles on an engine rebuild from a very good shop I've had a lot of experience with. Burnt exhaust valve was cause, cracked head was replaced.
- new clutch
- Very little rust. Limited to the rear wheel well and bottom tailgate pinch seam (even that's not bad). Absolutely nothing around the glass or gutters. I pulled the little plastic door step carpet transitions and there wasn't a speck. Rockers are good too. Frame is solid (with surface rust and the inner C channels looking like they all do). Upper shock bar is either unscathed or super well redone, no rot. I spent 45 minutes to an hour poking around with a screwdriver and magnet looking in all the usual places.
- new lift and matching set off 33" bfg k02s that have a good amount of life left.
- clean title
The bad:
- I'd say at least 50 percent of the body panels have dents from small to big. It's long lost any hope of being a restoration candidate or show car. It was gently laid on its side at one point.
To boot, there's a cheap rattle can paint job over the root beer brown. (For me personally, all this means is I wouldn't have guilt for using it like it's meant to be).
- it doesn't run well. Aftermarket Weber carb and a hack desmog, with an aftermarket distributor (do these also need recurves?) Runs very rich, hard to start and won't idle. He doesn't have the skill or interest to tune the carb and I noticed within about 10 seconds of opening the hood no less then 4 open vacuum ports on the manifold so I think there's a lot of low hanging fruit there.
- no front carpet, head unit, bumpers. Interior is a 6 or 7 I'd say. He's leaving the 6 pioneer speakers.
- play in rear pinion bearing.
- it hasn't been driven but a few times in the last 5 years or so. The cruiser came into his lap easily and it just never was his thing, had a lot of other hobbies.
- A/C is not working, though it was working really well recently. Good chance a recharge would do it.
- I ran it around the block twice and in that time the temp needle got to 3/4 in 100+ degree weather. Lots of original coolant hoses and a Toyota rad that looked too new to be original.
I can share the price but I'd like to hear raw estimates of what it's worth. I couldn't get a lot of pictures before my phone overheated so some are from the listing
One last important thing: I'd like for this to be a forever car but I need the option of not selling it at a loss, per my wife's conditions. This is because either an addition or new home is in our near future with our growing family. I also need to decide very soon.
I would run away as far as possible from that rig
that rig is a LONG way from being a forever rig, lots and lots of rust everywhere, there is alot hiding
you didn't state how much he is asking, but to answer the question, hard to say if it is a good buy or not
Oh wow. Guess you would have thrown up to see my old 60 then.
Thanks for the input. He was asking 4500 which seemed really good to me.
What a mess. I guess for $2500 you could try to get it running but after that, it's toast. Run.
2500-3000...buy a used frame for 2000-4000. As mentioned the bodywork is extensive but that frame is a horror show.
No air cleaner on a new engine?
I'm not too bothered by the frame. That inner c-channel of a common issue, and the rest of the frame seems okay.
...but that is not a "little bit of rust" body. Those fender wells being completely rotted apart is a very difficult fix. Most importantly, is this thing is absolutely covered in bondo. You can see it in the 1st picture of post 2. There is a lot of hidden rust that you can't see.
I don't think its beyond saving, but it's a project.
I decided to pass on it. Thanks to all for honest and realistic input.
For what it's worth, it was pretty obvious where bondo was and wasn't on account of whoever not trying too hard. I don't think I did the cruiser much justice by only taking pictures of the worst of it, I am confident nothing was hiding in rain gutters, around the windows, upper tailgate, or the floor pan. Hammering a screwdriver around the frame suggested everything but the inner c channels was just surface rust. You can see the peeling remains of some frame sealer done years back.
Still, if I had aspirations for it beyond a trail rig I...well I just wouldn't. That rust around the fenders likely would have seen at best a repair on par with the rest of the body. As for the frame, I'll be on the hunt for a rolling 80 chassis regardless of whatever 60 i do end up with. The idea was/is a cruiser that's solid enough to not fall apart but also one I wouldn't lose sleep over when hard trail damage occurs.
Edit: oh yeah, there was an air cleaner. It was removed while trying to get it to start with starter fluid
As usually, it's almost impossible to really advise on something like this without a specific goal for the vehicle, and overall budget and mechanical experiance
looks fine for a trailer beater / wheeler that can fit a family. 60's are great for this, throw a SOA and get the AC working and go have fun
