GM alt, proper pulley
I just ordered a P/N 7294-12 GM 12si alternator. Parts person said it comes with a V-belt pulley (good!), but couldn't determine if it was a wide or narrow-groove.
Which is it likely to be, and if I need to swap to a wide-groove, where can I get one? My current Toyota alt has a narrow, and the harmonic balancer I just swapped in uses a wide groove.
Since the plug on the rear has a 12:00 position, if I need to move it to 9:00, is it really as easy as un-bolting the back plate and rotating it? Aren't there internal connections thru the back plate that will not like this?
Unbolting and rotating is fine as long as you don't seperat the two halves. Just rotate.
Find someone who will sell you a wide grove pulley. Look in FS section.
Just put your stock Toyota pulley on there off of your old unit.
Jeremy
His stock alt pulley is narrow and the crank pulley is wide.
Sounds like I need to scrounge up a Toyota pulley, mine is narrow. I wonder how that is? I'm positive it's a replacement Japanese alt for my rig.
Thanks all.
