Glue advise
Sandy Utah area
My hood flutters and my roof rattles, I think the problem in both cases is that the sheetmetal is pulled away from the support members. I've read before on here what to use for the hood (some type of liquid nails?) to fix the hood issue, I assume it would also work for the roof. Im going to pull the headliner here soon to get at a wire and do the roof issue as well (and seal up the port installed rust holes). Also, is there a solid waterproof through connector for electrical that people like here? As long as im in there I might as well add those in.
Thanks.
Paging @NLXTACY , he knows the connector (actually several here will know), but believe it is like 9pin cannon thing.
Something like this.
The hood flutter, I would get some body adhesive for metal to metal, and you need to remove your hood to do this, after cleaning, light sanding and using, wax and grease remover apply the steel to steel panel adhesive it's going to be a 3M type product, that is 2 parts and requires a special caulking gun, do not try some liquide nails garbage and have to clean it later to use the correct product
Forget liquid nails. It dries rigid and hard.
You want a polyurethane sealant. The link above looks ok, or Sikaflex etc. Uses a standard caulking gun
Polyurethane stays flexible, sticks to a clean surface like sh i t sticks to a blanket
Another vote for Sikaflex as its amazing and will serve you well.
For wires coming in I use cork seal, stays soft, conforms well, and does not dry out.
When you say cork seal, you mean just run the bar wires through the hole and use corkseal to seal it? or do you recommend a through fitting? I would like to make it connectable and disconnectable since my rack isn't on full time. then again, I could just use mertipac for the connectors. thanks.
So sikaflex is just a brand and they have a grundle of products, do you have a particular one you use? Sikabond? sikapower?
Iirc sikaflex 222 I'll double check later
Sikaflex 221
I use seam sealer from SEM. It comes in a 2 part gun, and is not cheap, but it is really awesome stuff.
I used U-Pol Tiger Seal for my hood about a year ago now and it's doing great.
