getting spark plugs - pita!
sportbiker929 said:
The start cold this morning wasn't as easy as with the bosch's. Before i would pull full choke and it would start like it was fuel injected. This morning I had to pump it twice. The power was back to normal and ran really good. I have to run it with the air on to see if the results are the same..
Mitch out
the way it was explained to me... the boschs in a stock LC don't have enough volts to spark properly. This wouldn't be an issue w/ yours since you have the DUI w/ 50,000 volts (iirc). You could put in just about anything, i doubt it would make much diff - as long as they are gapped properly.
I am thinking you are correct
