Build Georgia 1980 FJ40 Build Thread w/ Cummins R28 Diesel
Doing a little configuring with the dash I wanted to make. Keeping it simple stupid as they say. The main dash will have just a GARMIN ZUMO XT 2 GPS (IO use these on my adv. motorcycles) as they can take a real beating, and have never failed me. Also, all the hardware you see here came from BulletPoint, as I really liked their quality and modularity to add/move accessories around. So, on top of the GPS will have simple two cell phone holders, and two USC chargers below them.
Because this is a topless, diesel, I opted to NOT run a stereo/speakers set up as I didn’t want to tempt anyone from stealing that setup, and two, be removing stereo/speakers and all the wiring, etc that goes with it, trying to simplify it as much as possible. We I am going with is dual wireless/bluetooth headsets from CARDO that allow rider & passenger to talk easily over topless / diesel sound as well as share music, etc.
So, need some help here. In my build, I opted to go with the City Racer Electric Steering Column. This is standard for FJ 33 Spline count, and the Wheel I got from ICON 4x4 Steering Wheel is a 36 spline count. My question is simple. Is there anyone out there that knows of a 33 to 36 spline adapter so I don’t have to sell this wheel from ICON as they don’t take refunds once you purchase from them. I know, boneheaded move on my part, lesson learned, etc…just trying to see if there is a way to make a square peg fit in the round hole here. Any help, links, ideas are welcomed, and thanks all in advance.
Machined some sleeves to be as tight of a fit as possible. 2 sleeves through the box section and OG frame, and 2 sleeves above the OG frame. This is tucked as high as possible without going past 40% of the frame height overall.
One last check .
The most that this will see at full droop both wheels.
Started the day off Saturday with making a new radiator support mount. Trying to make a 'bulkhead to carry all of the cooling parts and power steering reservoir for a clean package. Some alu Tig practice over the weekend.
Fender on for a clearance check, front core support will have to slide in to the engine to within an inch or so of the fan.
Deaeration tank fits nice here. Need to add 2 more bungs.
Lower rad hose will get fastened to the frame
Power steering hoses should slip through here perfectly to the PS cooler mounted below the FMIC.
Everything will have to go down on the frame, clear the pitman and then back towards the fan. No problem
Once we can get this buttoned up and pushed back, I will start to get the fenders back together for final fitment.
We were so close to cranking it up for the first time, but it was a miss. Time to try again.
