Gear ratio inputs
CO
Fellas, have an 80 with a 5.3 LS with a 4 speed...37s and what I believe are the stock 4.11 gears? Drives great offroad...I don't wheel much, but plan to get up some nastier roads to my hunts with this. Also is driven around town when I'm home. Freeway at 70 I'm about 2100 rpm...in the wind, on a slight climb (lots of hills in CO) it really seems to struggle to keep 4th gear. I'm happy with it around town and on logging roads, but wondering if there is a compromise to get a little better gearing for the highway as well?
Anyone with a similar setup have a better suggestion for gearing? This wont be a crawler, it'll be a mix of roadtrip and Forrest Serice roads, and hoping to take some of the big passes down in the San Juan's this summer for fun.
You can get a pretty decent idea of how you'll like deeper gears, by just locking out overdrive and cruising in 3rd gear for a while. Your RPM's at a given speed will be not quite as high as your current 3rd gear RPM, but it will give you an idea.
Swapping to 4.88's will give you roughly 400 RPM more at 70 MPH, which might put you right where you want to be?
Also, which transmission do you have? The 4L60e has a taller overdrive gear than a 4L80, which would make the overdrive RPM's roughly the same 4L60/5.29's and 4L80/4.88's.
4L65e
Wait with the mighty LS it still struggles @ 70mph?? (Sorry inside joke here on mud)
I think 37's deserve 4.88's it would take you from 2100rpms to 2500rpms on the highway but I think it would be worth it.
