gear pattern check 9.5 e-locker
Hey guys I am going through and replacing the bearings in my rear 9.5 e-locker third. Could you check the pattern and give me some feed back. Thanks.
Sorry for the crappy pics.
What @nukegoat said ^^^
If you are re-using your original gears, already have a pattern that is worn in, and you'll want to keep that with the same pinion depth and backlash.
Used or new gears? Did you keep the backlash and pinion depth the same if used?
They are the original gears. I was thinking that as well so I put them back together with the original shims. But I saw zuk had been setting them deeper and to tighter back lash and I wondering if I should as well. I have never setup used gears before:
Toyota gear install
I just learned this expensive lesson too. In my case I had to take the entire ARB locker out to remove a broken piece of plastic that was jamming the locker in the "locked" position. I had no way to measure the backlash before taking it apart because I was on the road. I got going again and drove the truck without the rear drive shaft to keep from messing up the gear afterwards. Got it to a shop and they fixed the locker and reset the gear to "spec". Not knowing what it was before. 2000 miles later and it howls, and is causing a vibration. New gear time.
Lesson learned: You must check backlash before taking it apart, so it gets put back right where it was before.
I couldn't have done it any other way because I was on vacation in Colorado, and stuff happens. That crappy little piece of plastic has me up to $1000 not including lost time, hotels, eating out,........ BUT, the cruiser got us home, and I still had a great time with the family. Looking forward to this summer!
I am not familiar with ARB lockers, so I am having a hard time envisioning the problem. Do you know where the backlash was at for it to fail. Mine is set to 0.007" which seems good and in spec. Also, the 9.5 e-locker uses shims on the carrier not those big adjustment nuts like most of Toyota's thirds.
If you don't remember the original backlash, you're probably better off with it slightly "loose" than the other way around. New gears will have a different setup criteria than old gears - don't necessarily follow the same advice for new gears that you would for reinstalling the existing ones.
And, for what it's worth, your pattern looks incredibly soft - like you aren't applying resistance to the assembly as you rotate the pinion or carrier. You need to apply a lot more pressure (I recommend using a rag in your hand like a brake on the pinion flange while turning the carrier)
Backlash was not the first problem. The bad first generation ARB design is the problem. Inside the ARB they put a plastic cage which is pushed on one side by the air pressure, then on the opposite side they had a ring that locked the entire unit together. The plastic had 4 big windows in it that went around the spider gears and grabbed the locking ring on the opposite side. The thin plastic broke and left a piece jammed in such a way the locking ring would not retract. I had to remove the entire locker, then unscrew the 10 or so small bolts that hold it together, and pull the spider gears out in order to get the plastic piece out. This freed up the rear axle so I could drive on pavement without the axle locked.
Back lash was fine for the past 9 years the locker had been installed. I simply could not measure it before pulling it all apart and getting me back on the road. The new "spec" backlash it was set at after fixing the ARB internals, was off enough that the gear didn't like it at all. It began getting louder and louder, and set up a vibration. Don't know how long it would have lasted, but when the old lady says something about it, you know it is LOUD and can't be ignored.
Not knowing the original backlash on your gear before disassembling it means it will be a guess to which side of "spec" it had worn in to. You may get lucky (I hope you do), and the gear will be close enough to what it was before so that you get many more miles from the gear. For me, it was too far off, and it started to eat itself up even though it was reinstalled within "spec backlash". Only time/miles will tell. It won't leave you stranded. The howl is unmistakable and progressed over 300 miles.
wanted to ask this question then to @nukegoat. @tornadoalleycruiser is helping me on my ARB diffs from a FJ40 as I thought there was some play in them. We were going to take them to another MUDder to check out.
After reading this, it makes me question if you can do anything to a set of used diffs.
What adjustments can or should you do on a set of used gears?
Thanks, nukegoat. I was using a rag but I will try applying more pressure.
I am wondering the same thing. I tore into these like I would if I was replacing the ring and pinion and didn't measure anything. But, how could you ever match the preexisting tolerances? You can measure backlash, but with new bearings preload and pinion depth will change.
As with most things, "it depends."
It depends on
1) Your willingness to tolerate some noise and other nuisances
2) How much you're changing parameters (are you adjusting them substantially or just slightly?)
3) How worn the existing gears are
One advantage to just refreshing an existing set of gears is that a lot of variables are under control - you don't have to deal with the small deviations between housings that affect things like the angle the pinion points at the ring, etc. These become problematic when swapping housings and maintaining the existing backlash and pattern are more critical in those cases.
I'm by no means an expert here, though, and it should also be obvious that each situation is going to be a little bit different. Part of the fun of this hobby is messing around and seeing how things work. If you don't have the patience for it or the thought of mechanical problems gives you anxiety then I'd suggest just buying new gears if the old ones are wildly out of spec.
