Gear oil ?
High Desert, SoCal
Hi
My neighbor gave me 6 qts of amsoil 75-90 gear oil. What applications could this be used for on my 73 fj40? All the drivetrain is stock. Also how much is required for trans, (3speed), transfer and diffs ? I looked thru the tech section and didn't see anything mentioned about capacities. Finally got the birfs back in.
Thanks Brad
You pretty much answered your own question. You can use the gear oil in your tranny, transfer case, and diffs. I fill them all until the gearoil comes back out the filler hole. The capacities can be found in the FSM and even the Haynes manual if you really want to know.
haha if you didnt know gear oil went in your tranny transfercase and diffs... what have you been putting in them haha i also fill not to over flow but till i can put my pinky in and just feel the oil right below the hole,
Geez guys Excuse me
I just wanted to know if the weight was right? Also wanted to know how much I needed to do a complete job. I didn't want to drain and then run out and not have enough.
Thanks Brad
3 spd trans. refill capacity of 80W-90 gear oil- 1.8 US quarts(1.7 liters)
4 spd trans. refill capacity of 80W-90 gear oil- 3.3 US quarts(3.1 liters)
T-case refil capacity of 80W-90 gear oil-1.8 US quarts (1.7liters)
the diffs about 3 qts?
you mean to tell me that all these years water isnt what i was supposed to use? uh oh :doh:
