Gear lube/whining
On my new FJ40 (never owned one before) it whines a fair amount while driving. I'm sure some whining is normal coming from the drivetrain, but how much so? Also are these engines (72 F engine) commonly noisy? I realize there is just a piece of sheet metal between me and the engine, not sound deadening material or anything. The noise doesn't bother me a bit as long as I know that it's not signs of something wrong with it. My question is, is what kind of gear lube should I put in the diffs, transfer case, and transmission? I want to change all the fluid out, and I figured 80-90 would work fine in all of them, but I didn't know if I should use GL-5, if I needed any type of special additive, or what. I know some vehicles require an additive to be put in with the lube for certain diffs. It's just an old vehicle and I don't want to do any more damage than the wear and tear that's already there. Can somebody give me some suggestions on this? Also, about how much fluid will I need to drain and fill everything?
Unless you have some aftermarket limited slips in the diffs, regular gear lube is fine. I believe they are supposed to run straight 90 weight, but all I have been able to find locally is 80w90, which is what I have in both diffs, trans and transfercase. Also be sure to check your transfercase fluid level. The seal between the transmission and transfercase tends to go bad. Then the oil gets pumped out of the transfercase into the transmission. If you remove the fill plug from the transfercase, and nothing comes out, then way too much comes out of the transmission, you know you have a problem. When the transfercase has no oil, it gets really loud.
The 3 speeds are whiny, and one of the worst culprits is the transfer case idler bearing shaft.
Swap out all the lube with 80-90, see where that puts ya.
Good synthetic gear lube($$) , or just heavier weight lube may help some.
If after your change your fluids you find you still have whining, it is most likely your transfercase like Dave suggested.
I had a dying rearend at one point, that produced a solid amount of noise too. :D
When you change the gear lube, pay attention to the metal on the magnetic drain plug. If you see little flakes or chunks of metal (as opposed to fine dust), this is consistent with the failure of a bearing; usually the idler gear shaft and bearings on the transfer case. Rebuiding the transfer case is not a big deal.
If your gear lube looks like this: :doh:
hehehehe...that's good mike...shouldn't you be working? :flipoff2:
seriously...three speeds suck noisewise. oh, yeah, and speed wise. when do you really notice the whine? is it primarily at higher rpms? if so, that's just the tranny, may as well get used to it. there was some oem sound deadening, but oftentimes it's long gone, or most of it is gone. it's the chunky sections that you find on your trans tunnel and the cowl in front of the pedals.
Looks like he voted four times....
I like the whine, it means I'm moving.
Ed
Ok, so the whine is determined to be normal. What about the engine noise? At idle it sounds fine, but under moderate throttle at mid-high rpm it sounds almost like a knocking noise. But no noise at idle. Every time I've heard a rod knock it's just been at idle and gone away when reved. I am wondering if I should try running higher octane gas? It's 86 here in Texas, and 88 and 90 is also available. This guy I bought it from was really honest and up front with every quirk on this thing and he had the engine rebuilt about 500 miles ago, spending $1800 at the machine shop and $2500 total on the rebuild. He said he did not rebuild the head, but that the engine is rock solid. Is this noise normal? The thing runs like a top, lots of torque and even power across the rpm band.
As Pin_Head says, a "knock" under load may be what they call "pinging." May be from too much advance, so besides increasing the octane of your gasoline, you can retard the distributor a couple of degrees.
Ok, I will look through my books and see if I can't retard it a little bit. The guy I bought it from said that he went to get a cap and everything for the distributor a long time ago and it turned out to be from a 59 Chevy. It is not a vaccuum advance. Maybe the advance curve is wrong on this distrubutor. He also gave me a new in box (though box looks 20 years old) Mallory Unilite breakerless distributor. I might try putting it in also.
my dearly departed nuclearlemon had a 5000 mile rebuild in it when i got it yet, the main bearings were toast. idled great drove around the block fine...at 38mph started knocking like a sob. rod bearings were fine...mains were gone. change the oil and see if there are particles...if you have bearing problems you'll know.
I did change the oil just a while ago, and the oil looked great, no particles at all in it. It really probably didn't need changing, but I figured it had been sitting there for around 9 months so I changed it. I was surprised that it took a hair over 7 quarts! I also changed the front diff, transmission, and transfer case fluid. I tried to do the rear diff also, but the drain plug is rounded. I don't know how I'm going to get that sucker out of there.
. I was surprised that it took a hair over 7 quarts! .
should take just over 8 with a new filter. as for the rear diff plug, you can weld a nut onto the face and yank it off with that. i think i used vice grips on my old plug.
Looks a lot like anti seaze..
I have had a sligth midrange knock for 2 years and 15000 miles.
I heard it more when I did the valve clearence properly.
Run strong so I ignore it.
I would get the right distributor in it first off.
