that's what I want to read .. ( ear ! )
I would need to start working in better intake ..
Already got it covered.
I'm such a bad GTurbo 12H-T owner...... :-(I guess it could go into the intake manifold direct, just as long as it bypasses the turbo and IC.
Baby steps.So the new ones are called the Grunter 2 and Bad Boy 2? What is the recommended maximum boost for the new turbos? Will they go safely to 30psi or are they all about coming in at very low rpms?
Negative the crank breather always needs to be plumbed in pre turbo. If you put it in post turbo the turbo will pressurise your crank case with 20psi of boost and blow oil out of every seal and possibly damage the engine.
Sorry to hear about the turbo damage, I hope the engine faired better![]()
of course you're right re the pressure into the sump. Oh well, breathe to the atmosphere it is then. (through a pair of catch cans in series)Can only vouch for the bb2, but it gets to 30psi easily enough, found that out on first test drive....... Previous turbo boost had been set at 14psi on controller, so did not think to touch it, wound fuel up about 1/4 turn for starter and the needle nearly jumped off the dial when mashing skinny pedal in third. I think it went to 35 but that was enough of a scare for one day.Baby steps.
My gut tells me that the standard snorkel and air box is really restricting its breathing from mid to high revs now, so a 4 inch intake system now has priority over large front mount intercooler, along with nutting out some sort of rev gauge, might have to look at plugging one into the IP.
What is a safe max boost for the 12ht?
Mudbludger, what sort of boost are you getting at 1700 rpm? When do you reach max boost?
So what is the max EGT any of you run? I've got a 1HDT. At the moment it never gets above 425 Celsius even on a 37 degree day but my turbo setup is very conservative at the moment. When the FMIC goes in I'll try to push it harder.
