Gas Door- Whats Wrong Here
Houston, TX
The lock tab does not contact the upper tab I have had this in every configuration . It was ok before i took it apart for paint. Whats wrong/
I welded an extension on the cylinder pawl but it does not secure the door closed,, Is the pawl suppose to behind the front tab or the rear tab. Is the rubber necessary for anything oyher than a cushion for the door ?
The door rests on the rubber pad, the latch catches on the tab behind the one with the rubber pad.
