Currently it will start up, run really poor, and die on it's own regardless of throttle input.
Jumping B+ to FP doesn't change anything (just to rule out the AFM wasn't killing my fuel)
The issue is also intermittent, sometimes it starts up and purrs like a kitten.
I've done a lot thus far and haven't replaced anything without good reason as to not be throwing parts at it. It seems in searching for my problem I've come across a hundred other problems that certainly weren't helping.
For myself and possibly anyone in the future reading through this, to summarize what I've done up to this point;
Initial issue
-Car would bog under load, and only accelerate up to 20% throttle input. Anything beyond that it would misfire, bog down, and backfire as if it was running super rich
-Codes 24, 32, and 41
-Tested TPS, was out of spec
Replaced with OEM Toyota TPS and adjusted via FSM (numerous times to ensure it was perfect)
-Tested AFM, was out of spec
Replaced with
eBay reman unit, which bench tests within specs. Read some wary posts about the
eBay units so keeping that in mind still
-Car still ran poor and nothing changed
-Tested wiring from TPS and AFM to ECU, all good
-Decided to pull engine harness for a proper inspection
95% of the connectors had broken tangs and super brittle (I'd been leaving them plugged in with hopes and dreams
-Upon removal, the rear knock connector was completely disintegrated, and the wire was broken. Also most of the FI wires were super brittle and had parts exposed.
- went through the harness, replacing any brittle/broken wires, replaced all connectors/terminals/wire seals EXCEPT for the ECU terminals. I spent hours researching what parts I needed and thought they were the same terminals as the engine connectors, they were not. Those wires aren't subject to the same conditions as the engine connectors are and were all still in good shape. I used motorsport butt connectors for any splices, including splicing the FI wires to the ECU terminals (because i didn't have those terminals and didn't care to spend hours to find what I needed and wait for shipping).
-new harness installed
-still runs like doody
-Fuel system was last gone through like, 6 years ago. There was no change when unhooking the FPR from vacuum and I knew I should go through it all as normal maintenance.
-replaced FP, filter, and regulator.
-filter was totally full of crap
-no change in running, although didn't really expect there to be
-found injectors 1+2 weren't firing. Ordered the 4-hole Bosch injector set from CruiserParts preemptively, under the thought that 1+2 were bad (I've had to replace injectors before and figured it to be a good time to replace all of them with new)
-pins #10 #20 on ECU had loose connection, probably from me sticking my testing pin into them to check circuits as well as age. Pressed the inner tang in to have good contact w/ ECU and all injectors functioned normally
-truck runs smooth, took it for a wash and when I got home, I went to bolt the ECU in and the truck died. Found a number of other terminals had loose connection as well. The problem child here was the MRel terminal (power supply for Main Relay).
-now the issue is an intermittent gremlin. Sometimes the truck runs smooth, sometimes it's so poor it can barely make it up the driveway. The only thing changing between running good and bad is the wiring near the ECU which leads me to believe I still have an issue somewhere there.
-ive checked every pin for good contact, and I've metered the entire fuel injector circuit, TPS circuit, and AFM circuit and it all tests good. Have even quadruple checked them.
-I tested each electrical output/input of each ECU pin via FSM, and all was good, come to find out this was while it was intermittenly running well, so need to go back when it's experiencing the issue
Want to add, under GOOD conditions, on startup, it has a funky idle for about ten seconds which goes away with revving and also on its own. Like 10 seconds of it not knowing what it wants to do then smooths out.
Might be related to initial closed loop switching to open loop, or possibly related to the issue I'm chasing. Also possibly my O2 sensors as they've been on the truck for a while, although they test (resistance, not via analog test on the diag port) within spec.
Currently it's running pretty rich, evident by the spark plugs being covered in black soot
The only thing I have left to do is redo the ECU pin out tests under poor running conditions. Outside of that I'm about ready to throw in the towel as I don't have the necessary time I need to get deeper into this. I know a good Automotive electrical shop locally (the owner was my electrical instructor a few years back) and might take it there if the pinout test doesn't show anything. I'm a full time mech. engineering student and need to be focusing 95% of my time on studies, not on my Land Cruiser
I'd also like to find someone locally who'd be willing to let me try their known good AFM, just to double-ensure the
eBay reman one isn't secretly bad. I've heard some poor things about them, mainly bench testing good but actually being the contrary
