FZJ80 Alignment Problems
Oklahoma
Hi folks,
My 93' Cruiser is having problems eating the hide of the front tires really fast. It wears out the inside and outside treads really fast, leaving the middle part. It also pulls to the right fairly bad.
I took it to Toyota locally and had an alignment performed after I bought it. It still pulled to the right afterward and they told me it was because the existing tires (Goodrich AT's 285/75/16) were already worn funny.
I went to the tire store and bought two brand new tires of same make and size and had them put on front. It still pulled a little to the right. I have had the tires on 4 about 6,000 miles now and its time to rotate them and the new tires are already worn pretty badly on the outsides.
When I had the truck in to Toyota they told me they could not adjust caster or camber. The adjusted the toe a bit.
Most of the numbers on there alignment sheet were in but a couple were slightly out. They said it was not a problem.
Have any of you folks experienced this? Do I need to look into having my Kingpins or whatever they are replaced? It might be an illusion but sometimes I think I can see the tires leaning out at the top. Someone suggested I might have a bent axle housing.
Thanks for any help.
Does it have a lift? Post the alignment spec & pics of the tires.
a lift will affect caster
loose/worn trunnion bearings will affect camber
both can cause excessive tire wear.
post alignment specs and details about your rig.
I believe low tire pressure will cause increased wear, on both edges of the tire.
I set my alignment the other night. It is still all jacked up. -.02 degrees on the camber. Barely out of the green so not so bad, I suspect trunion bearings, as the wheel bearings are new. Caster is also about -.02 degrees but it is plenty bad enough for it to pull to the left all the time. But, with my caster out my driveshaft angle is good. So, I will let it pull left and not destroy my driveshaft, atleast until I get a DC driveshaft. I did set the toe though. LOL
Mine isn't bad enough to wear tires, just pulls.
D
The rims are stock aluminum, Tire size is posted above, 285/75/16. No lift, stock springs. My truck has in excess of 237,000 miles. Odometer sticks sometimes and I just bought it a few months ago so it could have alot more mileage.
I agree with the statement that low tire pressure can cause outside tire wear but this is much more rapid wear than that type of deficiency.
FRONT
Left Caster min 2.00 max 4.00 and mine is 4.03
Right Caster 3.78
Left Camber min .25 max 1.75 and mine is .37
Right camber is negative -.23
Max Toe is 1.0 per side for a total of 2.0 and mine is .3 left , .7 right for 1.1 total.
Under Secondary Angles there is one listed SAI with a min of 13 and max of 13 degrees, I don't know what it is but mine are 13.4 and 13.85 respectively.
Included Angle does not have a spec but mine is 13.77 and 13.62 degrees respectively. Toe out in turns was not measured but spec is 1.3 degrees.
is your steering tight or sloppy? might have worn out tie-rod/drag link ends. it would be a good time for a front axle service w/bearing.
yes, the only thing adjustable is toe and centering of the steering wheel. But there are other items that effect the steering that can wear out and might need replaced. I rebuilt my knuckles (replaced trunnion and wheel bearings) and tie rod and drag links ends at 247k miles i really tightened up the steering and front end.
I fixed a truck with a bad pull by replacing a bad TRE. Three shops didn't find it and they all adjusted toe. The problem with a bad TRE is it will move under load so while the shop might see good alignment numbers on the rack it won't be so on the road.
Also, not correcting for caster means that the axle is rotated out of position. This will also effect the camber and toe numbers but not that much. So if you caster is out that should be the first thing you correct and then address other problems with the alignment.
What is a bad TRE? How would you adjust caster? Trunion bearings?
Tie Rod End. Trunion bearings, do the same thing as a ball joint more or less. They allow the knuckle to pivot when you turn the steering wheel.
D
Thanks That helps. I'll start there.
