Hello Mud! I've lurked on here for a while and joined recently when I became serious about purchasing an 80 LC. I search classifieds, CL, ebay and various other sites almost daily looking for that special one.
2 days ago I found one not too far from work so I decided to pop in yesterday to take a look. I'm looking for advice from others as to what opinions are based on the following details.
1994 FZJ80
202k miles
Currently located in NY (checked its history, it's only been in NY since 2010, previous to that it spent its life in California)
The good: Exterior is in good shape for its age, no large dents dings or otherwise, paint is in good shape, very tiny bits of surface rust, panels are straight, lines look straight, bumpers are decent (for 22 years old).
Interior needs to be detailed, but it doesn't smell. Cloth interior and the seats are fine, buttons and gauges etc. work.
Engine purrs like a happy cat, no noticeable sounds, ticks, knocks, coughs or otherwise.
Frame is near flawless. Absolutely apparent that it spent the majority of its life in a salt free area. Even most of the rubber looks fine as well, and it does look original. Diffs don't show signs of leakage, lines underneath (brake etc.) look fine.
Now to the bad or potentially bad...
From what I saw right away it will need some work.
It needs a front D/S door handle, front P/S window regulator or greased track, the window is very slow to roll down.
ABS light is on when idling
Needs a rear wiper arm
Needs new tires (3x are the same, 1x is different)
Exhaust leak near the manifold
Birfs need servicing, probably overhaul (caked on grease and grime around the area)
Engine leaks oil - it doesn't look terrible, but does look like it's been that way for a while since there's some build up below the valve cover, and a smallish stain under the engine on the ground. I'm thinking valve cover gasket for sure, maybe something more. It looks as though most everything under the hood is original (dizzy cap, wires, rad, hoses) so pretty much all of that would get replaced.
No diff lockers (not a deal breaker for me, especially since this rig is on the cheaper side)
I think I'm forgetting a few other things. I didn't have time to test drive since I got to the dealer a little late, so I may go back this weekend to test drive or maybe next week.
The silver lining to this LC is the price. The place wants $2k for it so I can justify needing to fix/replace parts. I'm mechanically inclined and have done 95% of the work on all of my vehicles, usually in driveways, with my array of hand tools. I don't mind at all doing the work that needs to be done.
So, is it a good deal from what I've described so far?
Sorry for the long post!
1994 FZJ80
202k miles
too.
