- Location
- United States
This trailer has just been fully refurbished by Adventure Trailers after a trip from Vladivostok, Russia to Magadan, Russia. Build price - $15,000. Asking $12,000. Please email me for more info and pictures. jthresher@automotive-events.com
Here are the specs...
Chaser Trailer Chaser Trailer Kit Chassis,Trailing Arm Suspension Cargo Box with gas strut assisted lid, Drop Leg Jack, Rubber Matting, Cargo Tie Downs, 2" Rear Accessory Receiver. Standard
Powder Coat Color: White with Black Chassis &
Fenders
Fox Coil Over suspension, rated for 500 lbs of payload.
Nose box Steel Powder Coated Nose Box
Fuel Can Set Two Fuel Cans & AT Holders for Trailer
Water Tank 19 Gallon roto-mold water tank with 1.25" opening, 1/2"
drain plug and pump
Partner Steel 2 Burner Stove with wind screens
Shelf-Chaser Utility shelf for Chaser (16.5" x 43" x .75"), shaped and
finished hardwood ply with locator pins.
12V Power Auxiliary 12V Power wiring w/ night light,
ARB Adventure light, 3 fused outlets, battery tray and hold
down
31D Valve Regulated AGM group 31 deep cycle battery 105
Amp
EEZI 1800 Eezi-Awn Series 3, 1800 Roof Top Tent 70" x 96
RACK BARS 3 Thule Rack Load Bars on Adjustable Track
Tent Fitment Mounting & fitting
Chaser Tail gate 16" x 32" with locking T-handle
latches.
MaxCoupler Multi Axis Coupler, 3500 lb, Class II
Engel 45 Engel MT-45 liter Fridge/Freezer
Transit Slide Lock for Engel MT35 & MT45 Fridges
3 BFG Mud Terrain T/As Tire Size: 265/75 R16
3 Suzuki Equator/Nissan Frontier RimsOffset: +30mm Backspacing: 5.70"
Bolt Pattern: 6-114
1 Wheel Adapter Wheel Adapter from 6 on 5.5 to 6 on 144.3
BK2-100 Bearings (L68149/L44649), seal (10-19), 1.719" I.D. &
pin kit.
Pivot Rod with two 1/2" washers and two 1/2 x 13 lock nuts
TAAS Bushing TAAS polyurethane bushing
15 misc 12mm lug nuts, 12 for trailer tires, 3 for spare 1.73
Electric Braked Axle Upgrade with 10" drums, includes
break-away kit
SwingAway Swing away tire carrier for Horizon & Chaser trailers.
Bolt pattern 6 on 114
Fenders
drain plug and pump
down
Amp
latches.
Bolt Pattern: 6-114
pin kit.
break-away kit
