- Thread starter
- #21
It sure feels like it when I sleep on it...
Padding it with some appropriate thickness rubber is a good idea.
Yes, at least on this body that one rib sticks up higher than the others.
I could potentially persuade it with a hammer, but at least for now it sticks up higher
Now I'm curious if that one should be higher, or if it is the result of some activity from the prior owner...?
To the extent that stiffening ribs are proud, I can shim the underside with plywood, cut to fit shims, or rubber neoprene sheet as needed.
I'm reasonably sure that the fore/aft dimension will need to be supported/shimmed where it gets lower over the second row and forward. I'll need forward structure/legs, etc.
A sheet of plywood will smooth out minor irregularities.
Off to the local wood store to see what they have in stock.
Your mounting approach is great too. You must've put a lot of thought into this! Thanks for sharing your insights.
