Fuel separator
Are you talking about the "Fuel Vapor Separator"?
If so then you'll want to keep that..
fuel-separator-jpg.262870
Separates the liquid from the vapor, are you sure fuel Vapor separator is bad and not just one of the rubber lines leaking
If you have an earlier model, then you'll have two of those, one on each side, behind the cargo panels. Really should keep them and a charcoal canister to control the gas fumes.
let me echo the question about verifying it wasn't a hose...are you sure it isn't a rubber hose? If it is the vapor can, just about any vapor can can be modified to work. there is also a check valve there that could be cracked, so narrow down where your leak comes from. As others have stated and I have experienced, you don't want to bypass that or the charcoal can; and it has nothing to do with the environment, and has everything to do with immediate personal comfort...unless you like huffing...
Yes, it runs up to the Char. can then to carb. Mine goes from can to the air cleaner ( no carb ).
74 only has one with four vent lines from the tank going to it.
That's three votes for a hose, now..,
