Ok, I pulled the inbound fuel line at the filter, jumped it, and no question it's getting plenty of fuel to the filter. I was actually surprised how much it pumped in just the few seconds I jumped it. Which brings things back to the previous observation, of virtually no fuel getting past the fuel pressure regulator.. Normal or not??
Edit: I found this little tidbit in a post from PabloCruise several years ago, dealing with a no start issue..
"The bottom line is that I believe my problems were caused by a clogged return fuel line. I think the ECU was doing all it could to manage idle when there was almost double the specified fuel pressure in the rail. I am guessing the ECU had injector pulse width pulled all the way in.."
I'm thinking perhaps that's what's going on if that FPR is stuck closed. I know there should be pressure at the CSV, but I don't recall it being as high as it is now. I don't have a fuel pressure gauge, maybe a harbor freight run in my near future.., but it seems abnormally high at the valve.
Update. I pulled the fuel pressure regulator off, and just to see what's what, stuck a piece of tubing on the rail side port and tried to blow through it. Tried my best, but couldn't get any air to pass through.
Took 50psi at from the compressor to get the valve to open... Too much? I think I read it should be down around 38psi?
