fuel pressure ?
Bozeman, MT
I am trying to figure out the problem with my engine again, the spark plugs have carbon residue on them so the engine is running rich. It also wont accel. past about 12-1400 rpms when I put it to the floor, possibly flooding? So I am going to put a pressure regulator in the fuel line. I was just wondering what the spec on that would be? What is the recommended pressure so I know what to set it at.
Carbon could be from a number of things worn rings, worn valve guides or a poor ignition.
Take a look at the sight glass on the carb, there is a dot in the middle to show the fuel hight. Over or under can easily be corrected by adjusting the float. Instructions usually come with a rebuild kit.
Fuel pressure should be 4-5 lbs, although I'de take a look at the ignition. Points if you got em. A dwell meter is best to set them. Old wires don't help much either.
Fuel pressure from a stock 2F should be 3-5PSI - I assume 1F is similar.
If you have a vac gauge - most also check fuel pressure. Disconnect fuel hose from carb, insert vac/fuel press gauge into fuel line, start engine (yes, it will start and run for a while with just the gas in the carb), check fuel pressure reading. Turn off ignition and watch the fuel pressure gauge as it should slowly drop back to zero over about 1 min or so. Quick fuel pressure check before you go spending $25 on a regulator (which I seriously doubt you need anyway).
Post up some more info also. What happens when you foor it - sputtering? Backfiring? Will it rev higher if you gradually apply gas as opposed to just flooring it? Have you checked to make sure the PCV valve/lines are connected properly and the valve is operating correctly? How is the timing?
AndrewT
