Fuel delivery issues
bellfower ca.
Hello all
I have a 91 80 series and been having problems with what seems like the fuel is cutting out. I changed out the fuel regulator , filter , and fuel pump. Every one of the changes helped a little but still happens. What's wierd it just happens randomly and never stalls or stops running. Then comes back to normal. When i did the fuel filter i found a bunch of brown rusty fuel come from the inlet side of the filter. I also drained some fuel from the line going to the tank and it was clean. Also the tank looked brand new when i looked inside it.
Any thoughts?
Hello all
Any thoughts?
Fuel sock.on the pickup tube. There are two filters. Did you change both?!
Since you've changed the fuel pump/strainer, regulator and filter, I would change the damper. That's about the last item you can change besides the injectors which typically don't cause the issue you are having. The damper you will need a crow foot wrench to remove and install. Here's a source I just found: OEM Fuel Pressure Pulsation Damper Kit for Land Cruiser FJ62 FJ80
Here's another thread about the damper and how to check fuel pressure on the 3FE: Intermittent Starting Problem Solved
I have a new pressure dampener. I got it months ago with the regulator. But i cant find where it goes. Can someone give a hint? I thought it was just the wrong part
Goes behind, below and a little right of the back of the valve cover.
I still cant find it. I see a metal line that runs along the drivers side of the back part of the valve cover then makes a turn behind the block towards the passenger. But i cant see anything or even feel anything other then that hard line. If i cant see it or feel it how the hell can i change it?
i finally found it. its nowhere near where i was looking. end of the fuel rail drivers side next to the valve cover. its under a thick wire loom and has a black cover on it. after reading older posts it mentioned a screw on top of it. my new one doesnt have this screw. anyway people mentioned the screw coming out or screwed in too far. so i decided to unscrew it about one full turn. not sure if this new one i have is the right one. anyone ever installed one that doent have a screw on it?
so i went to harbor freight and bought a fuel pressure gauge kit. this thing is awesome. it has attachment to replace your banjo bolts on either a fuel injection line(i used it for the cold start valve) or bigger ones that should fit the fuel filter bolt. so i ran the pressure gauge to my windshield and monitored it while driving. and this is what i came up with. at idle the pressure was 35psi. at acceleration it goes up to 40psi. i assume these are correct numbers since i couldnt find anything online. anyway the cruiser had an episode while all connected and nothing changed in fuel pressure . all was perfectly steady which brings me to believe my issue is something else.
so l was thinking when did this start happening ? and i remember when i first got this cruiser i decided to do some maintenance on it like i do with all my vehicles about once a year. clean the throttle body and maf sensor. do you see where im going with this? i unplugged the maf harness and took the 2 screws off. tried gently pulling on that sensor and it came out a little bit. noticed something is wrong i pushed it back in and put screws back on. then tried to start it and wouldnt start. so i took it apart and noticed i bent these little fingers that rest on a circuit board. straightened them out with needle nose pliers. and then it started and ran good. but now im wondering if that might be the problem?
sorry for the long journal. hope someone has some input on this
I finally changed out that air flow meter box. And that was the problem. This thing has way more power. Ended up buying a refurbished unit from rockauto. This unit of course not for a landcruiser but fit exactly the same as my old one. If anyone wants that part number just contact me. Cost was $109 includes core charge which makes it under $100.
Thanks again for all that chimed in
