Electrical.
truck cranks but won't start and no CEL.
Replaced fuel pump and tested so I know I'm getting fuel. No spark, checked at plugs and distributor. So I replaced rotor, cap, coil. Plugs looked good and wires as well. not sure where to go next? Was going to replace distributor next or is there something else?
Thanks everyone!
When you say "no CEL" do you mean you don't get a CEL when you try to start it? If so you aren't power. Check fusible link. Check the 15 amp EFI fuse in the fuse box under the hood. Check the EFI relay under the hood. My money is on the 15 amp fuse or the fusible link.
Ok the EFI fuse was the first thing I changed, I'll pick up a fusible link tomorrow since those are pretty cheap are those model specific? Or will anyone do? Also how do I check the EFI relay? Or do I just swap it out?
Sorry for all the newbie questions this is the first truck I'm really trying to work on.
The fusible link part number is 90982-08264. They are about $12-15. You get them from the Toyota dealer. You should always have a spare in your glove compartment. Same with the relay. You can swap out the relay with one in the Driver Side kick panel (down by your left foot). I believe it is the top right round one. Just double check the part number on it.
There is a systematic way to trouble shoot this. This is a step-by-step process that Jon Held put together. He's smart. Follow this guideline.
http://www.sdsysdesign.com/tlc/images/Strife/3FE EFI Diag.pdf
Lsifj40
So I followed that guide. I have power to the fuse box and all my fuses in there, relay and main EFI are all good or new I then checked resistance in the coil and igniter and still no start and no CEL this is why I'm stuck and replaced cap and rotor and think it may be distributor. I ordered one because no one on Maui had one. I'm checking here for other things I could troubleshoot while it comes in because well hell that may not be the problem either.
Tools r us
It's a 92
No CEL=No start. Full stop.
Stop replacing parts. No need to even crank the starter.
Disconnect the AFM connector by lifting up on the spring clip on the connector. DO NOT REMOVE THE 2 PHILLIPS SCREWS ON THE HOUSING.
If your CEL comes back on with the key in the ON position before cranking the motor, you have found the problem.
Thanks jonheld so I disconnected this
And all a got was this
No CEL
No CEL with the key to run, usually indicates no power to the ECU. I try not to work on the early rigs, so not up to speed on the issues that cause this on them and don't have an EWD. Is there battery voltage at the B+ terminal in diagnostic connector?
How are you inspecting you fuses? Are you just visually inspecting them or are you testing with a voltage meter set to ohms? Your answer should be the latter. You have power coming out of your EFI relay correct? If so, check the fuses again. If they are good check the MAF/VAFM as @jonheld has mentioned. It also helps to know year you're working on.
Lets start from the beginning.
What is the history here? Was this truck running fine one day and stopped the next?
Were you or someone else under the hood or doing any work on the vehicle before this happened?
More info is needed.
Ok from the beginning, truck was running fine I had done no work on it. It's a 92 I have had it for almost 8 months it has 250k. We drove it one evening it ran great left it overnight and next day wouldn't start. About a month before AC stopped working and didn't know what it was never used it much so wasn't a big priority. As I was checking out the truck for the current problem found the fuse had blown and replaced it, not sure if that has any bearing.
Also I'm the epitome of backyard mechanic I change oil and minor stuff replaced belts radiators things like that.
So when this happens I asked for help mechanic first said it was the fuel pump and wanted to charge me 950 for the job and that was more than I was willing to pay so I found the part myself and in a couple of hours had it in and working. That didn't work. I then looked things up here and that's where I checked and replaced EFI fuse and relay. No go, since after saving myself 800 doing the fuel pump myself I didn't want to ask the same mechanic so asked a friend he said he thinks it's electrical he checked resistance like in your write up and everything checked out so I replaced cap and rotor since the ones on it looked a little burned again no go he then said next step was the whole distributor haven't done that yet.
Someone suggested fusable link but my dealer here doesn't carry them so haven't tried that.
So that's where I stand now. Hope that helps, and thanks again for all the help and suggestions
Also I was thinking is it possible the truck has been throwing a code from beginning and the bulb is out or disconnected by the guy who sold it to me?
I suppose it is possible that the bulb has been removed, but then you would have never gotten a CE light when the truck was running properly. Of course you might not have noticed it either, so it's hard to say.
The fact that you're not getting spark points to the ECU not arming the EFI system.
An open coil in the distributor wouldn't cause the EFI system to shut down and it would throw a code.
Fusible links/fuses can be checked with a meter, if you have one and know how to use it. There are 3 fusible links off the positive battery terminal. 2 run to a black plastic junction box and 1 goes to a grey connector. They have been known to go intermittent.
Are you getting +12 to the B+ (pin 8) terminal in the check connector on the firewall with the key I the ON position?
You should also make sure the terminals of the EFI relay are getting the proper signals. The picture has the factory wire color codes that are attached to the pins and the description tells you what pin does what. You can bypass the relay by jumping 2-4 for diagnostics. Don't leave the jumper in or it will drain the battery over a day or 2.
Ok sorry it's taking me so long but finally had time I'm only getting 4.6 on the b+ terminal in the diognistics port and EFI relay is getting +1
What do you think
Ok so it's running now I unplugged and replaced EFI relay and running on its own. Was elated to hear "Diego" running again AC and all working great. Then I put it in reverse to back out of driveway and started sputtering like it wanted to die idle was dropping it felt like you were letting out the clutch with no enough gas in a manual trans car. Put it back in mistral idles fine put it in drive and idles and drives great so now I'm stuck with no to very bad reverse any ideas?
Thanks so much for all the help guys
