Stalling issue...need some insight
Celina, TX
I searched through some threads last night and this morning and couldn't find anyone with the same issue I am having, so if it's been covered and I missed it, then I apologize.
91 3fe with 217k miles. Hasn't given me any trouble in the time I have owned it (5 weeks, 1300 miles). Most of my driving is on city streets, 15-25 miles a day at 50 mph or less. A little slow to start, but runs fine.
Left work last night at 8:00. Started fine, drove through the parking lot, out on to a side street, and up to a stop light for a major road. Once up to about 40, it died. Coasted into a parking lot and started it back up fine. Back out on the road, it continued to sputter and almost stall. Check Engine light would flash on and off, but not stay on. Once the engine was up to operating temp, it was fine. Drove it 15 more miles home with no issue.
Took my kid to school this morning. No issues through the neighborhood, or at the school, but started stalling once I hit the main road. I could shift into neutral and start it back up, but it kept stalling. I turned around and went back home to get my son's truck. By the time I got back, it was running fine.
Seems like it is giving me issue while in open loop, but runs fine in closed loop. My thought is that would be the opposite if it was a bad sensor. Maybe a bad ECU? I caught a glimpse of the voltage gauge last night when it was stumbling a little and I thought it may have read a little higher than normal, but I was too busy negotiating traffic while trying to get it restarted this morning, so I didn't notice. Is it possible the alternator and/or the voltage regulator is causing a spike that is throwing the ECU off?
Save that overthinking for after you've done some basic diagnostics: Vacuum leak such as the intake tube, battery cables/connections good and tight, etc.
Done any recent work on it where you might have bumped/damaged something?
Only thing I've done recently was replace the fusible link and junction box about a week ago. I'll check the battery connections and related when I get home tonight (didn't think about that).
I thought about vacuum leaks, but I would think the issue would be in reverse...present themselves when warm, not cold.
Vacuum leak on an intake hose or fuel sock/strainer/filter needing replacement. Start with the easy stuff as @CJF mentioned.
I'll do the fuel sock and see what it does. With the age and mileage, it probably needs to be done anyway. Then I will start checking for a vacuum leak somewhere.
Thanks for the help!
Remember, if you decide to open the fuel tank, you're supposed to replace the pump access cover gasket. If it's been replaced recently, I'd reuse it, it's pretty thick rubber. If it's never been replaced, it needs it.
Thanks for the heads-up. I ordered one with the fuel sock and filter.
I would check for a tear in the intake plenum before turning a single bolt. The flap in the AFM runs the fuel pump.
I will check that ASAP. Thank you!
Do not remove the 2 phillips screws on the AFM connector housing.
Removing the 2 screws will allow the connector to move in the housing and damage the thin wires internal to the AFM.
There is a spring clip on the connector that lifts up to unplug the connector.
Do not remove the 2 phillips screws on the AFM connector housing. There is a spring clip on the connector that lifts up to unplug the connector.
Yes! I have read not to do that, but thank you for the reminder!
Found a leak in the intake tube, right after the AFM. It's the nipple in the rubber tube that runs around to the side of the throttle body.
Question is...can I remove that hose, cap the nipple on the side of the throttle body, and replace that section of intake with something without a nipple? I'm trying to research on my phone and can't figure out what that hose is for. If not, it appears I can get a replacement piece, but it's pricey.
You really need to get a replacement. Short term solution could be to wrap it in electrical tape, I have seen that but it is not what I would trust long term. Personally I would buy a new one before they are NLA, then you'd have to get a metal race intake tube ;)
I don't think tape would do it...it's pretty deteriorated around the nipple. I thought about trying to epoxy it. Not sure that will hold either. It looks like it was repaired once with some kind of silicone sealant, but that didn't hold.
Black urethane to the rescue. Fixes windshield gasket leaks, intake tube cracks, anything that needs to be water proof, etc. NP1 is my urethane of choice.
I'll grab some of that tomorrow and give it a shot. I'll probably still pick up a new intake hose at some point and put it away for future use. I guess I better start making room in the garage to horde parts.
