FSM for 200 series
I've enabled a secondary client. This is a screenshot showing the trackers with SEEDS and PEERS. I don't see any peers on the list.
I do see several SSL errors listed for the torrent, but the client GUI isn't telling me which trackers have the error.
ETA: This is the HASH of the file I'm seeding:
Code:
CF1BA674B5796AADE66D13A51E7F4C56B8FB9195
I have the torrent downloading. Its stuck at 0% downloaded. Right after the download started, it went from showing 3 Peers to 0 Peers and has not progressed beyond 6MB downloaded for 10+ minutes. I'm going to let it run and hope it finds a better connection eventually. If I'm able to download successfully, I'll be happy to seed pretty much 24/7.
Using this link:
magnet:?xt=urn:btih:cf1ba674b5796aade66d13a51e7f4c56b8fb9195&dn=TheCompleteTLCFSM2021.iso&tr=udp%3a%2f%2ftrackr.opentrackr.org%3a1337%2fannounce&tr=udp%3a%2f%2fopentracker.io%3a6969%2fannounce&tr=udp%3a%2f%2ftracker.torrent.eu.org%3a451%2fannounce&tr=https%3a%2f%2ftracker.tamersunion.org%3a443%2fannounce
Using this link:
I got it to work. Download completed and able to access using instructions for setting up Abyss. Currently seeding. Thanks!!
Downloaded and set up the iso image. Thanks @linuxgod , the time and effort you put into this is really appreciated.
if it may help anyone, I struggled with transmission for three days then finally used bittorrent and it downloaded right away, took about 4 hours.
I used windows IIS to set up the server following @greynolds instructions, many thanks man, it took me just few minutes to set it up. I'll be seeding whenever I'm online.
Thanks again guys
Any chance I can get one of you fine gentlemen/women to seed it again? I've had this thing attempting to download in the background for a week or so now, with no progress.
Lemme know when you're done. I don't particularly like seeding. I think you'll have to use BitTorrent Web.
Seeded with Transmission... yet I don't have any trackers to use. Been awhile since I've created new seeds.
Not to be difficult, but can I ask you to double-check this URL? My torrent client can't parse it.
See my earlier post about using BitTorrent web. It just uses a browser interface, but it's still just a BitTorrent client. Nothing weird.
I also tried seeding with Transmission; I also ran into tracker headaches.
I did. It didn't work at first, but I figured it out. The loopback address (127.0.0.0) was throwing it off, so I just had to replace that. It's still downloading, but thank you, I've been trying to find this thing for ages now.
If anyone else is trying to do this rn and it's not working, try this:
I'll semi-permanently seed with a magnet link once I have it downloaded, for anyone else who needs it in the future.
Post when you've completed the download so I can jump through the myriad of hoops required to fully uninstall a modern torrent client.
It's been running in the background all day, and it can see 1-2 seeders, but it hasn't downloaded anything except the metadata. Not sure what the problem is, but whenever you want to kill it, go for it. I'll just watch the thread and grab it the next time someone posts it. Appreciate the attempt regardless.
I’m always seeding but for whatever reason sometimes it takes a while to start
I'm dumb as hell, the original magnet link wasn't working because I haven't torrented anything in a while, and my client's tunnel settings got out of sync with my VPN. @linuxgod I can see yours now, thank you.
Downloading now with one peer. I will leave it up seeding for a while as thanks and can put it up again later if needed. Just ask!
Any place to buy the physical book for a 2016 LX 570? Looked on ebay and saw nothing. Saw some for the earlier 200s but I'd like the updates for the newer ones. Downloaded Transmission and I'm not getting anything. Thanks.
Transmission seems to be having issues with this. Some people have had better luck with different clients.
Also I’m not sure that they even published a hard copy for the 16+ rigs. I can say the wait for this electronic version is worth it.. when it is up and running and you’ve learned how to navigate things it is much more compact and easy to use than the old paper copies. Embedded links being you right to other procedures instead of having to go find the page, etc.
