Front seatbelts removal..
Calgary, Alberta - Canada
I would like to replace the front seatbelts and wonder what it takes to remove the existing ones? I can see the bottom anchor bolt, which is no problem getting at, but what about the wrap-around piece of trim that goes around the door pillar and covers the retraction mechanism? Does it just pry open or is there a magic trick to take it out?
Any help is appreciated. I searched the forum but didn't seem to find any relevant info.
Cheers,
there is a thread on cleaning the belts and making them retract better. It's in the fAQ (I think)
New ones would beetter of course
Ya', I'm a fan of just replacing them - though it irritates me that oak isn't available anymore - once you've lived through a couple bad crashes, you don't take seatbelts for granted.
The trim piece can be easily removed by sliding it up three inches and then prying it off. The B-pillar tapers as it goes up which is why the higher up it slides the easier it is to remove.
rip it off! Just do it.
Does anyone have any further photos or instructions besides "slide it off or rip it off"? I was hoping to work on my non-retracting seatbelts this weekend, I have the 97 with the up and down sliders on the B pillars but can't get to how to remove the slider part, there must be a bolt in there somewhere? The FSM was not helpful on this subject. Thank you
To remove the seatbelt from the slider at the top of the B pillar, you have to pinch the buttons that allow the mounting point to slide, and pop the bolt cover so it hinges up and exposes the bolt underneath.
Awesome, worked perfectly, thank you. Cleaned belts with hot water and Mr Clean, amazing ..
Repeated process until nasty water no longer turned brown when dunking belts. Took 4-5 batches yo remove the funk.
That has not been my experience, and they aren't cheap to buy new.
I had a 91 Nissan that went in back in 2003 with bad seatbelts. The parts manager had them install new stuff for free, he is the one that told me they were warrantied forever. Of course that was Nissan, this is Toyota. It would make sense that on a serious safety issue like that they would extend the warranty out for the life of the vehicle.
I did try that angle with a couple of dealers and none bit, and had to buy my own. They were required to be changed for NA market belts when I imported my HDJ81's as they check for the CMVSS/FMVSS tags on the seatbelts when you get RHD's safetied here in Manitoba.
In a situation like that Nissan would more than likely had a product safety recall on the seat belts. On safety recalls the NHTSA forces the manufacture to make replacements at their cost no matter the age or condition of the vehicle.
It helps to remove the front and rear sill plates. The pillar cover slides under those. With those removed the pillar cover should slide right up so you can pry it off with a hook tool easy.
Cheers,
@Cancruiser we just removed the front belts and sent them off to Safety Restore to get the webbing replaced and retractors/tensioners cleaned out and refurbished.
Here's what we did. Move the front seats all the way forward to give you space to work with. Get a 17mm ratchet and 10 mm ratchet and a trim removal tool.
For the seatbelt slider at the top, we used a trim removal tool and you gently pry the cover from the bottom and it will flip up and expose the screw.
Use the trim removal tool to loosen up the front and rear sill plates and gently pull straight up to loosen or just remove them. Next you can remove the piece that covers the B pillar. Start from one side and pry gently and once that side is off you can just pull from the other side and take it off. When you take things off, it helps to label everything with scotch tape.
Remove the top bolt with the 17mm socket. Once the cover is off remove the lower bolt with the same 17mm. There is an orange washer that sits between the metal and the hardware, just fyi. Remove the bolt, and remove the lower seatbelt assembly. Then I just screwed the bolt back in for now. Use the 10mm socket to remove the bolt above that. That should be about it. I'm just writing this from memory but any questions ask away.
