Front/Rear locking diffs troubleshoot question
Statesville, NC
Hi all,
I recently purchased a '97 that has the front and rear locking diffs (diff lock knob) that weren't working, figuring I might be able to solve the mystery with the help of this great community. I'm new to DIY /"wrenching" and still learning the names of the different components, so please correct me where needed.
Ok, here's some background info...
I took it to dirt field and put the main shifter in Neutral, and then moved the 4WD shifter to 4Low. Both the ABS light and the center diff lights come on (solid, no flashing), and it locks immediately. When I put it into Drive I can feel it's fully engaged as it wants to go! Then, when I put the main shifter back into Neutral, I push and turn the Diff Lock dial to "RR" (rear), and nothing happens, no blinking indicator lights (the center diff and ABS lights are still on, of course). And when I turn it all the way to "FR-RR" (front/rear), same thing, nothing changes-- also, I don't "hear" anything happening (or trying to happen) either, but I also wouldn't know what to listen for. I did the "go do a bunch of figure 8's" stuff too. So my first guess was maybe this could be an electrical issue since there's no indicator lights coming on at all for the Front or Rear diffs (maybe no signal is making it to the front or rear diffs). So I looked for fuses... I don't know where the fuses associated with the diffs are, but I found a small-ish fuse box under the hood (near the power steering res.), and I didn't see any labels on the box that lead me to believe it had anything to do with the diffs, but I tested the fuses in it anyway and they were all good (but there were a few empty slots, not sure if anything is missing or not). I also tested the fuses I found under the left-hand side of the dash (left of the steering wheel), and they were all "good", but again I didn't see any labels mentioning diffs... My owners manual doesn't seem to mention any other fuse boxes... Question: is there another fuse box that I need to locate?
Anyway, I then crawled under to take a look at the transfer case area and I see this wire harness nearby...
What is it, and does it have anything to do with sending the electrical signal to lock the front and rear diffs? Also, as you've likely already noticed, there's what appears to be a ground wire that's not attached to anything on one end -- what's it supposed to be connected to?
BTW, I pulled back the rubber boot to inspect that plug and I see 3 wires, I think they looked ok...
My gut tells me this is an electrical issue, and that the front and rear diffs will engage once they get the signal. Overall, this LC runs very well and appears to have been fairly well taken care of, but it does have other electrical quirks, too -- like the radio flipping on and off constantly that I had to disconnect it. And the antenna motor keeps trying to telescope/extend for 30 seconds after it's already up (what's up with that? it's crazy noisy). I mention that because I know there are a bunch of other threads that talk about front and rear diffs not engaging, but they all seem to have blinking indicator lights that just won't go solid, but mine won't even come on at all; so again, I suspect a loose wire somewhere, or a bad (insert electrical thingy here).
And I didn't want to go tinkering any further without first checking with the pros (you guys). ; )
Thanks for any suggestions, tips, or guidance!
:cheers:
First of all, are you certain that your axles are actually equipped with the lockers, and that the PO didn't just slap that dial-switch in the dash for the extra resale value?
No, I'm not certain.
However, when I pull the dash back, the Diff Lock knob is wired into a main electrical harness that has the backlight dial/plug and other electrical elements-- the electrical tape looks original and untampered with (and dusty/dirty). Still, I recognize someone could fake that too, so what else can I look at/look for that would tell me? BTW, here's some pics I just took, sorry the exposure/contrast isn't great...
@kristofferson the easiest and most fool proof way is just looking at the driveshaft side of the axles. You will see an electric actuator if you have diff locks. You were under there taking pics of the electrical connectors would be easy to snap a couple more pics if you aren't sure what you are looking at.
Ok, here's the pics of the rear and front diffs, driveshaft side of the axles -- I see no actuators. (Unless I'm not following your instructions correctly and pointing in the wrong places).
Still does anyone know what that loose wire is in the original pics I posted, and know where it needs to be connected?
Thanks for your help, guys! I appreciate it.
Well, sorry to say but your axles don't have the actuator for the lockers. Don't know if you bought it from a private party or a dealer and if it's possible to get all or part of your money back.
I bought from a small dealer in NM, and sorta gambled buying it sight unseen just based on what he described to me. He was a nice guy and my guess is that he got it that way and didn't know either. It's an Antique Sage 40th that's straight, clean carfax, no rust, interior is in very good condition, has the original floor mats in the front, seems to have been well maintained, and runs great. The clearcoat is fading, but in a way, I kind of like the "patina" : )
Anyway, I'm still learning about these trucks and this is just one of those life lessons I'll have to chalk up. I think the only thing that bothers me is I find it weird that someone out there went as far as buying a Diff Lock switch, and actually wired it up behind the dash and bundled it/taped it into the main wiring harness, I guess in order to deceive a buyer? I just don't get that. But hey, they're just part of the world we live in, and there's certainly a lot more great people out there than the shady ones. This forum is filled with super helpful people, so much so, that I've never seen anything like it. Truly a great community here.
I think its more likely it originally had lockers, but a PO recognizing the value of them swapped them out prior to a sale to either keep them for personal use, or sell them separately as they have a pretty good resale value.
The sensor in the pic is (I believe) the VSS. not sure on the ground wire.
I don't care how nice the guy was, if it was advertised as having lockers, then you were cheated no matter what you paid for it. They have a term for that and it's fraud.
I'd certainly agree with you and would take the issue up with him if that were the case, but he didn't mention lockers in his ad - I had sent him a text and asked him if it had the Diff Lock knob, to which he replied yes. I see now that that was the wrong question; technically he didn't lie to me (and he may not have know either). The right question would've been to ask him to read the sticker to me, to which I would've learned that it was missing. Or, "hey can you turn the Diff Lock knob and let me know if the indicator lights come on?" to where I would know that at least it had the diffs, and I still would've bought it even if they weren't working. So, yeah I'm bummed that it's not what I thought I got, but at the end of the day, the onus sits squarely on my shoulders --and it's still a great truck. ; )
Wow, thats a new low if they did that to either sell higher or when traded in to get a better value by checking a box. In the end, if you are happy, all is well and that's what matters. Hope to see you out there soon on trails or events.
If you are near Uwharrie, the off road driving school is pretty awesome. I have factory lockers in mine, but they taught to drive without them for most situations with 2-foot driving. With good tires you will be fine in the Carolinas.
Cool - I didn't know about that. Where can I find more information on the off road driving school? It sounds perfect for me. I live in the Weddington area, so going to the Uwharrie isn't far at all.
Oh, and BTW, I don't think the dealer was trying to scam/profit from it, as I didn't pay a premium for it (just $7500) -- If I had paid $10k, then yeah, I'd be pretty upset. ; )
And I am going to remove the knob and replace it with the blank panel; just so everything is on the up and up going forward.
It's nice to see that you're happy with your deal, even if it's not exactly what you hoped. Although you'll see posts from people who paid less, it's hard to say if they got better deals. Such is the nature of use vehicles. Some 80 series may still be worth well over $20K, others may not be worth keeping out of a wrecking yard. I hope time shows you made a great purchase!
It's also really nice to see you not blaming a used car dealer for not answering a question you didn't ask. A question you couldn't answer yourself after crawling under the truck. (A question that I couldn't answer after crawling under my truck when shopping.) A question that applies to 10% of the 80s made, and not many other trucks. A question that not many used car sales people could answer.
...and I think we all agree that bad people suck. It's a shame someone caused a truck to look like it has lockers, that doesn't have them. On the other hand, who is to say that whoever took out the lockers didn't explain to the next buyer what he had done? Then subsequent sellers could say (honestly) that they didn't know what that switch is for. Face it, there are car salespeople who don't know how to engage the low range four wheel drive.
Well, i am probably a couple miles away from you, on the edge of Matthews. Dave Rushing (roadstr6) is also in Weddington, about a mile from me, awesome guy to meet and know.
The best investment after buying the truck is this place. I am an engineering geek and like going to schools:
Uwharrie Off-Road Training Center
They have a 4WD 101 class that I strongly recommend, even though I can drive, these are awesome instructors.
Go to this also coming up, Jeep Jamboree at Uwharrie:
Hendrick Jeep Uwharrie OHV Jamboree
Then, overland expo, the motherload. This is the best event to learn and get understand how people do all this “overlanding stuff”, I love this event because of the diversity. Extreme Camel Trophy winners and trucks to simple Subarus and their hippy owners. Strongly recommend, always a few guys going
Overland Expo EAST
Sorry to see that happen to you but you definitely have your outlook on things right. You could keep the dial in case you add arb lockers and actuate off if it. Love the 40th trucks, it will be great. Get some pictures rolling!
For what it's worth the bottom of your rig looks pretty dang good to me.
Thanks Diggs, I found it in the southwest U.S. (New Mexico), near my in-laws. According to the car records online, it was purchased in Las Cruces, NM and lived there the entire time, except for a short time in Lubbock, TX, and then it was back in Las Cruces. So basically its lived in the desert, lol. Great for the no rust factor, but the paint has certainly taken a desert beating... ; )
