Just wanted to share my experience fixing my front locker this weekend, as I could not find any helpful info for my specific issue.
Light would stay flashing and no engage. NO AUDIBLE CLICK OF RELAY on passenger kick panel. Rear would lock up no issue, with audible relay click. This was the issue that I could not find any real solutions on. Plenty of great threads on which wires do what in the connector, and how to rebuild the actuator, but I couldn't find where anyone was able to test all of the individual parts, verify they were good, and still have no success.
I had ended up buying the front actuator from RockAuto (AISIN, ~$280), as I just assumed it was the actuator with all of the water crossings we did on water mark trail last year. Replaced the actuator Sunday, but no bueno. Bench tested the old actuator with a 12 volt battery and it worked fine.
So we back tracked a bunch of things. My buddy has spare parts for everything, so we swapped out the sensor with a new one, no luck. He had an extra Locker ECU, so we swapped it out, no luck. Had an extra "magic dial" switch, so we swapped it out, no luck. Rear locker worked fine, so we did not head to the relays near the transfer case.
The full manual has a great wiring schematic with testing processes to test the pins on the plug in the passenger kick panel, as well as the ECU. Since we had a spare ECU on hand, and got the same results, we tested the plug pins. All of the pins tested fine with multi meter (0 volts or 12 volts, depending on locker position). Continuity tests for the sensor pins also checked out, so we knew wiring was good from magic dial to ECU in kick panel.
So we jumped under the hood on the passenger side, up high near fire wall, and tested continuity of the wiring harness between that plug and the plugs at the axle. BOOM. No continuity to the sensor plug at the axle.
So I removed that wiring harness and started undoing the sheeting to inspect. At the actuator/axle side of the harness, there is a single grey and black wire that comes down the harness and then splits off into 2 wires about 6 inches from the end of the harness, to feed one grey/back wire to the sensor plug, and one grey/black wire to the actuator plug. That connection had come apart in my wiring harness. A little soldering, re-wrapping, and plugging everything back together, and my issue is fixed.
Big thanks to @2fpower and @StucknKS for having all the spare parts and for jumping off of their projects to help with mine. Started about 9am Sunday replacing the actuator, and had the harness re-soldered and back in the truck by 3 pm, fixed.
Hope this helps others who may be experiencing the same issue, and points them in the right direction. When "electrical gremlins" was mentioned on Sunday, I gulped hard, but it didn't end up being hard to diagnose.
Cheers.
Cheers.
