Front Hub Bolt size?
NYIronPig
YES I have a problem...
New York
Installing a set of warn locking hubs on my 74 -FJ40. Want to get some new bolts for the install. What is the correct size and are OEM still available before I start looking for stainless steel ones. Thx
Locking hubs? Wheel hubs? Brand of hub? Too many unanswered variables to give a response.
Sorry a set of warn locking hubs.
The 6 bolts needed to attach each locking hub is what I am looking for.
I would not use stainless--very weak. I would go grade 8 (hardened and tempered)--they don't rust like the softer ones do and they will take the torque. My .02.
Great what size then?
BTW, in addition to my previous post, check the length and use washers so as to not bottom out the bolt in the hole like I did and twist the heads off. Then I had to use an easy out to remove them. One of the simples jobs I could do became a night mare in a split second. Good luck.
