Front E-locker Won't Unlock...
The Sunshine State
I have a 12 volt guy e-locker switches in my rig and first thought that the wiring was wrong, because the locked light was on. But after locking the hubs I find that it really is locked. I click the switch and can hear the motor work but the front just wont un-lock. No matter how much driving I did or with the hubs un-locked (meaning its not bound up so it should unlock).
I saw a trick that you can unlock the rear with a screw driver does this also work for the front?
Thanks again,
-Al:beer:
Is this a hi-pinion FZJ80 e-locker? Just want to clarify...
I would try locking ONE hub, just to get things in the diff moving so any bind can get relieved.
Thanks again,
-Al:beer:
Just one thing to note, with Hubs unlocked you may not get locker to unlock.
lock hubs and try unlocking e-locker by making small turns. but before you do that check your diff oil level by removing filler plug One od the front of diff (NOT ON THE BOTTOM) and sticking your finger inside.
If level is Ok and oil looks good (not a milkshake or worst) then lock hubs and try to unlock locker while slow driving making S turns. Unless you can lift your front and with hubs locked try to rotate your front back and forth...
Yulp fzj80 High Pinion Locker.
I drove with the hubs locked and unlocked nothing will unlock it. Ill have to look up on how to unlock with the screw driver.
Diff fluid is fine, the axle has a fresh a rebuild on it.
Thanks for the help.
-Al
