Well hopefully christo or someone as smart will chime in.....adding weight for brian and i obviously cures our problem. But what does this mean, we need DC driveshaft?
sleeoffroad said:If you are running the heavy spring with no additional weight in the rear, that is the problem.
We never have these issues if the components are in good shape and the suspension is chosen correctly. How to solve it, either lower the truck, add weight, get adjustable arms and try to adjust and/or buy a rear cv shaft.
Busted!!! You got me there. Maybe I need a lighter spring 'til I get some lbs back there.sleeoffroad said:If you are running the heavy spring with no additional weight in the rear, that is the problem.
Does this mean pulling the shaft apart and reassembling w/ a 90 degree twist? If this were to make noise go away, are there potential neg. repercussions of running "in-phase"?Tools R Us said:Have you tried running the front shaft in phase?
brianinaustin said:Does this mean pulling the shaft apart and reassembling w/ a 90 degree twist? If this were to make noise go away, are there potential neg. repercussions of running "in-phase"?
brianinaustin said:Busted!!! You got me there. Maybe I need a lighter spring 'til I get some lbs back there.
QUOTE]
Or a Slee rear bumper.
BTW I am running medium Springs and am fully loaded with Front and Rear bumpers, a M12 winch and sliders. I do run the 1 inch Mr. Gaskets on the front that brings it to a similar height as the Heavies (See FAQ Thread). If you swapped out the heavies for mediums in the rear, you would not have to switch back later with a bumper. A bumper and drawer system with 400 lbs of parts would probably require the Heavies.
Cruiserhead05 said:Romer, christo,
I've just done some reading in the medium vs. heavy thread that romer referred to.
I'm running heavies all around with only a front ARB and no winch. Obviously my setup is not how it is truely supposed to be run, i should have a winch and rear bumper....So b/c i have the wrong setup im getting this GRR.
Now, lets say i add a winch, a rear bumper and my rides improves alot, but then i decide i want a little more lift and add mr gasket spacers in the front, my grr comes back.....at this point what should i do?
Go with a double cardan?
Lastly, i added 90 lbs up front last night and grr was gone. Next time i get a chance i will through some weight in the rear and see how she rides.
BTW, thanks for keeping up with this thread.
sleeoffroad said:... As for the rear, you need to turn the pinion up. In order to do this you have to change the length of the links.
Tools R Us said:Turn the pinion up for a CV shaft or down slightly to make the stock shaft happy.
concretejungle said:but not too far or you will make the tie rod and leading arms unhappy![]()
