front door window felt
I am starting to reassemble my doors and looking for imput on which type of felt I should use, the metal backed , like oem, or the rubber backed.
what do ya think guys ??? CCOT has the metal ones
Was there a significant change in the door style between 68 and 69?
Paging @Living in the Past
Would the 69 felts work? It appears to still be available OEM.
Door window felt should be the same from 63 to 74. Bug catcher to wing window was only major change in that door style
that is what I believe
the only FELT ,oem, was the window scraper type that goes on the inside of the window.
I know this is available and plan on using it. the stuff I am looking for goes in the window chanels in the upper door frame
I just looked through my records, I can’t find the receipts for my door rebuild parts, but I probably got the felts you described from either Toyota or Specter Off Road.
Just trying to help.
Here's a little tip.
Give us the details of your 40, year, any oddities, and a good description of the parts you are looking for. We've all built rigs here, we can all help but you'll need to help us help you. Give us as much descriptive information as possible.
I looked it up and cannot tell what it is from pict. I will try to get a better look where it goes with the part #.
my 40 is box stock 68 on the outside. It went from soft top to hard top with POs. It had been sitting in a field for 8 yrs when I got it.
Eng was frozen but it came with a 74 1F ,4 speed and transfer case which I have rebuilt and installed along with the PTO and winch.
it still has shoe brakes and I did the power brake and power steering thing. Every part on it has been replated, rechromed ,repainted, rebuilt or replaced with new. every piece of rubber is now or will be new.
the front and rear ends were torn down and various bearings, axel and bushings replaced so the chassis has finally been driven around the block , the drive shafts and universals were also replaced. All suspension was replaced with a 2 1/2 inch kit from SOR.
the instrument panel and all switches are restored as well as the windshield wiper, All the door hardware is new or restored and thats where I am now with the door window W/S questions. I have spent so much time on this I dont want any half ass parts on it, OEM has been my first choice from day one but when its not around I want the Best of the aftermarket choices.
The tub is on the chassis now I replaced the 2 side Quarters, rear sill, driver floor and trans hump stifner and both rock and kick panels
I was able to bring the original 3 piece running roards back to life, the inside of both doors were pressure washed, sand blasted and a slurry mix of POR15 wsa poured into and sloshed around to keep them rust free now they have sound deadener inside them also.
the inside and underside of the tub was coated with Raptor and tinted the same color as the outer body. The color is the original Fashion Green and the front bib and roof are the original Shell Ivory. So there is a pretty good detail of where I am now, still plenty to do, I hope to have it at the next Bakersfield Ca swap meet.
thanks guys for the info I have been getting from Mudd
P.S. I will try to get some pictures up when I get them into the computer, I got a good few !!!!!
All of the window rubber and felts, for steel doors, are available through toyota.
This is the fuzzy part that makes contact with the window. It's kinda like a black carpet material (required ONE per door)
Part Number:
68170-90300
This is the Rubber Piece that makes contact with the window. They kinda look like the rubber head of a squeegee. (Require ONE per door)
Part Number: 68161-60010
This is the Channel Run that was made of indestructible toyota material. Not sure what they were made out of back in the day, but now, they are made out of rubber with an inner "velvet side." (Require Three per door. Top and sides. )
Original Part Number (NLA) 68212-90300
Superseded Part Number: 68213-90300
Take note that the Channel Runs made by toyota are very similar to the ones made my CityRacer LLC. Rubber feels the same as well as the velvet inside. the only difference is that the CityRacer Channel Runs are a tad thicker than the Toyota ones. Not sure which ones are better in this case.
Part Number:
68170-90300
thank you, now that is the info I need !!!!!
Is there any particular reason the numbers in the pic don’t match either of the numbers listed incl superseded number?
