Front Diff Roar
Nashville, NC
I did a search and found a few things, but nothing specific, so, first a little background:
I did the baseline maintenance (or most of it is done anyway) including fluids. When I got to the front diff, some serious sludge came out. I searched around on here and came to the conclusion that my front axle seals were most likely gone, and I would have to replace them and repack the birfs SOON.
I filled the diff with some fresh 90 weight, finished up the rest of the stuff I was doing, including a good cleaning, and figured I'd drive it a bit to see what leaked from where. I expected some 90 weight to run out of the front axle somewhere, so far, that has not happened (about 2 weeks of 30 - 40 miles/day). I get a roar from the front diff now that was not there when I brought the truck home that occurs right at 70 MPH, and goes away when I drop below 65 or so. I checked the fluid in the diff, level is still good. Sooooo, now I'm thinking that the PO, or rather his illustrious mechanic, filled the front diff with some sort of sludge to reduce the noise.
First question, does this sound plausible?
Second question, pull the diff apart and look for something wrong?
TIA for any suggestions.
The sludge is from the knuckle grease getting into the gear oil; turns it into a green/black mudpie soup. No one would bother trying to put that in the diff on purpose, way too messy, but they may have had a heavier weight oil (80/90-140) in the front diff?? The more experienced mudders will give you some better advice, just wait a bit.
That's kinda what I thought at first, but upon reflection, and after reviewing some pictures of birf rebuilds where 90 weight got into the grease, I believe that maybe this was something that was put in on purpose to quiet the noisy differential. It took a good 24 hours to drain it out of the diff, was a good bit thicker than what I've seen in the birf rebuild pictures, and as near as I can tell, 90 weight is not leaking out of the axles anywhere.
That might be the case, never seen gear oil take that long to drain, usually just a couple of minutes is plenty of time to drain out the old gear oil. Wait a bit for some more experienced mudders who have torn into their differentials to chime in.
Is it a constant roar at 70 mph or only when you back off on the foot feed? Our 80 made lots of noise when backing off and it turned out we needed a couple of u-joints and a new yoke for the front driveshaft. Sounds like you've got a different problem, but deferred maintenance is a b**$* any way you slice it.
Mine is a constant roar that actually goes away when I back her down below about 65 MPH. I'm thinking something in the gears, or the setup thereof, but would really like someone who knows these things to chime in with their "HO"...
Diff roar or whine, assuming it's coming from the diff, usually means worn bearings. With the lack of maintainence, it may need new carrier bearings. It's not uncommon for the 8" diffs to need carrier bearings in the mini-trucks in the low to mid 100K range, when the diff oil is not regularl change. Doesn't seem to be as common on the 80s though, thankfully
Park the truck on a flat surface.
Chock the wheels so it will not roll.
Put the transmission in neutral.
Crawl under the truck and shake the drive shafts:
Where they attach at the differentials, both front and rear,
Where they attach to the transfer case, both front and rear,
Where the two pieces of each drive shaft meet; at the slip and stub.
Report back what you discover.
No. Replacing bad lube with good lube isn't going to make it any more noisy.
Well, the stuff I pulled out was "pudding like" and I mean some thick pudding. Thicker than the stuff I see pouring out of the birf threads where an axel seal was leaking. Darker too, dang near black. It just seems to me like it must have been put in there on purpose...
I just don't understand what else it could be if not diff noise.
After some searching on the innerweb I found this stuff called "DriSlide" that purports to quiet noisy diffs. Does anyone have any experience with it, or something similar??
Ok, here is what I found. I can feel a little shake in all of the universal joints, and it is metal to metal sounding. This tells me what I already knew, I need to get to Advance and get the dang hose for my grease gun so I can take care of that.
Other than that, there does not seem to be any slop. So, I tried turning each driveshaft. On the rear I get maybe 8 or 10 degrees of play before I can feel the pinion gear hit the next tooth on the ring gear. On the front, I get nearly 45 degrees!!!
OK, so after doing a little more reading and research, I'm thinking that the "excessive backlash" (if we can even call it that) is likely coming from more than one place inside of the diff. For instance, I likely have too much backlash in the pinion gear to ring gear mating (more likely some serious wear), as well as the side gears to pinion gears...would this be a safe assumption?
And, if so, could I pull it apart and check it without pulling my front axels out? In other words, can I pull off what looks like a "cover" under there with several bolts attached to the differential housing itself, or are all of the gears in there and just the housing stays in place so I have to pull the axles???
I wish I had my FSM @ work!!!
Also, as an update, after greasing the U-joints & slip joints the "roar" is still there, although upon further reflection, it would probably be better described as a "growl" or even "vibration". I got her up to 74 MPH on the way to work, the entire truck was "vibrating", so much so that I dared not take it any higher for fear of doing more/permanant damage. And, now that I have a better idea of "what it is", it seems like I can "feel" it at lower speeds as well, just not as pronounced.
EDIT*
Oh yea, I forgot to mention, I popped the tranny into neutral @ 70 MPH and the vibration was still there, although as I dropped speed, it lessened just like it does when I let off the throttle...
The rotational play in the driveshaft is the sum of all the play and backlash, including both drive plate splines, the birfields, the side gears, the spider gears, and the ring and pinion. I wouldn't worry too much about the play by itself. Did the old lube have a metalic sheen to it? Did you find metal particles and chunks on the drain plug? Bad carrier bearings make a rumbling sound and pinion bearings make a whirring sound that increases with increasing speed. Letting off the gas pedal doesn't change this noise much. Bad R&P gears whine and the pitch changes when you let off the pedal, but it typically doesn't just go away.
You could just bust into it and take a peek if you have the itch, but I wouldn't do it unless there was some metal evidence floating around in there.
PS Greasing bad U joints isn't going to help. There should be no sidays or in and out slop in the drive shaft or pinion.
So 45 degrees isn't "excessive"?? Why so much more in the front than in the back? I mean I realize you have the birfs up front, but do they make THAT much difference?
No real metal in the old fluid, some small "flecks", but I don't know what might have been pulled out before...
None of those noises that you describe sound like what I have. Mine is way more like a vibration that is pretty subtle at lower speeds, and turns wicked right around 70 MPH. It might actually settle down some at 80 I don't know, I've been afraid to try!!
That sounds more like a drive shaft problem, although noises are notoriously difficult to diagnose without actually experiencing them. What exactly did you mean by: "I can feel a little shake in all of the universal joints, and it is metal to metal sounding." This doesn't sound good.
Sorry to alarm you, the "little shake" could be measured in microns, and it was just a "tink" like the metal of the pin in the u-joint was hitting the needle bearings, and I had to shake it pretty hard to get that. I greased 'em up, and that is all gone now so I don't "think" that u-joints are the issue.
Someone in another thread mentioned drive shaft balancing...where would one get something like this checked/done??
Google your local area or you could ask any repair shop who they use. Some mudders have removed their front driveshaft and driven it that way to see if the noise goes away, but first you have to lock the center diff. You could also dump the front gear oil again and put in something like a Walmart 75W-90 ($4 something a quart) to see if it makes any difference. If the diff was full of pudding the new gear oil will be soupy again.
I pulled the fill plug, and clean clear oil ran out of it...so I think it's probably still alright. I crawled up under it today to see if I had thrown a weight or something...check out what I found...
Dude, you're missing something. That sucks. Is it the only one missing?
As the genius said "well, there's your problem..." You need to take the shaft off and move the u-joints around in free space. There should be nothing but smooth moving all around. They should easily flop around and not have any noticable movement. Look at the rubber seals when pushing the joint back and forth for reference when checking for movement between the caps and joint body.
Unfortunately, someone jacked those bolts around. Maybe they were over tightened and sheered off, or too loose and fell off. Either way, they should all be replaced. They are special fine-thread bolts and should only be sourced from Toyota. They tighten down to 54 foot pounds for the front. It always "feels" like a lot to me for such small bolts, but that is what they are designed for.
